It is currently Thu Feb 22, 2018 12:07 pm
 Post subject: swift gti 1992
PostPosted: Sat Mar 26, 2016 1:40 pm
Hi all well im back ,,, here goes right got my swift running after a lot of problems with maf ,,, now seems to have occurred an intermittent fault the car will start and run on occasion , then randomly nothing no fuel pump when car wont start ,, sometimes if i put a jump pack on it it will go driving me nuts can anyone help :cry:
 Post subject: Re: swift gti 1992
PostPosted: Mon Mar 28, 2016 12:02 am
Any check engine codes? Do you have a Factory Service Manual. The whole trouble shoot procedure for what your indicating won't take that long.
Fuel system:
ECM controls ON/OFF operation of the fuel pump by turning it ON via the fuel pump relay under either of the following conditions:
for 3 seconds after ignition switch ON.
While CAS (crank angle sensor in distributor) signal is inputed to ECM.
There is a code no 42 for crank angle sensor circuit
Hard or no starting (engine cranks OK)
-shortage of fuel in fuel tank
-Vacuum leak in air intake system
-Faulty fuel pump or its circuit open
-fuel injector circuit faulty
-fuel pressure out of specification
-poor performance of WTS or AFS
-Faulty ECM
If fuel pressure is felt at fuel return hose for 3 seconds after ignition is switch ON.
If not Flow Chart B-1
Is fuel pump heard to operate for 3 sec after ignition switch on
No or yes
no
1. remove fuel pump relay from main fuse box.
2. using service wire, connect "p" and ""w/Bl" wire terminals
3. Is fuel pump heard to operate at ignition switch ON?
If you can't find this 6E-60 page let me know and I will post it when I get a chance.
PostPosted: Sun Apr 10, 2016 4:40 am
Swami Topdown says Intermittent means wiring issues to me. I see corroded or loose connections somewhere in the harness in your future.
