It is currently Mon Feb 19, 2018 3:28 am
PostPosted: Sat May 07, 2016 3:20 am
Well - the car's still not going. Auto elec popped round on Thursday and we identified that the crank angle sensor in the distributor was not giving a sufficient signal to energise the ECU to throw an output signal to the coil. I've now fitted a new CAS and its still not giving a spark. Out of desperation I changed the distributor body over today with a spare I had. The trigger wheel was in a different place on the distributor shaft - bingo I thought. I rebuilt the distributor and still no spark. I do get an inconsistent spark turning the distributor by hand (when not bolted in place) but as soon as I refit it and crank the engine over I get no spark.
Completely baffled - I've now changed the coil, ECU, distributor, crank angle sensor, ignition power unit, and checked everything else at least twice.
Any ideas??????????
Cheers Adrian
PostPosted: Sat May 07, 2016 6:14 pm
Make love, not moderators
Bad MAF.
PostPosted: Sat May 07, 2016 7:55 pm
TheINCRide wrote:
Bad MAF.
That wont stop the engine firing up - it will still idle with a failed maf. It just wont rev. Good thought though.
Cheers Adrian
PostPosted: Sun May 08, 2016 2:25 pm
Actually your wrong. A bad MAF can prevent the engine from firing at all.
PostPosted: Sun May 08, 2016 10:10 pm
Thanks - clearly I'm getting conflicting advice from different forums. I have a good Mk2 MAF fitted now and I still have the same problems.
Cheers Adrian
PostPosted: Mon May 09, 2016 5:21 am
many times the maf will be good and the wiring is the problem.
it's a known failure for the wires to the maf connector to break and cause a problem. :wink:
PostPosted: Mon May 09, 2016 7:03 am
Thanks for your reply. I've spotted the posts on MAF wiring. Mine is all good. I'll keep searching
Cheers Adrian
PostPosted: Tue May 10, 2016 3:52 am
GREAT NEWS :D - I now have a spark. Problem was the EFI relay supply was coming from an ignition feed which was being isolated when the ignition key cranked the starter motor. The supply now comes from a stable 12v battery feed.
Next problem is I now have no fuel pressure. Pump is working fine and fuel is being pumped via the return. Everything was ok so I can only assume the FPR has failed in the fuel rail (the brittle problem encountered elsewhere). I have an adjustable FPR so will install that in the return line at the weekend.
PS: all injectors are firing correctly (checked with a sound meter).
Cheers Adrian
PostPosted: Thu May 12, 2016 2:01 am
Another frustrating afternoon working on the red Moke. I've now fitted the adjustable FPR and I have the necessary 40psi fuel pressure. The injectors are still firing (checked with sound scope) BUT THE CAR STILL WONT START. No fuel on the plugs so I'm guessing I need to dismantle the fuel rail and clean the injectors (which is a fairly big job in terms of removing a whole bunch of stuff that's in the way).
I'm going to leave it alone for a few weeks and find something more productive to do.
Cheers Adrian
