It is currently Tue Jan 16, 2018 6:24 pm
 Post subject: g13b variations?-obd1
PostPosted: Sat Jun 11, 2016 2:02 pm
My 1990 Swift GTI with OEM g13b motor was going to be replaced with replacement g13b...
So with good intentions, I was going to do timing belt,water pump,and seals before the install.
My problem is the timing belts don't match and i find the crankcase gear don't match.
The replacement motor crankcase gear is not as wide,and timing belt is not as wide. The water pump fits.
I believe this replacement motor is a JDM or EDM,but how can I tell? Where can I get proper parts for the replacement motor? It seems like slim pickings for parts for this car.
I've tried RockAuto, and looking on line with no luck.
~Painting Horse
PostPosted: Sun Jun 12, 2016 12:30 am
Strange can you load some photos. I'm curious because i replaced my timing belt last year and it was straight forward. and some one had said something similar here a while back. But i need to find the post.
PostPosted: Sun Jun 12, 2016 7:45 am
this picture is a mk1 twincam engine and use narrower timming belt , is that the motor you are talking about? (notice the different intake manifold setup)
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
SRP forged civic piston
cusco 1way LSD
PostPosted: Thu Jun 16, 2016 6:40 pm
@RP91GT- Strange But true, I can post pictures as soon as i can.
@Bostsgt- I got the motor with just head and block,so I can't verify the intake... Although, I would imagine this is the same engine.
I know there's number/code, i believe on the block. I wonder what would be the best way to source the timing belt and crankcase gear ..?
My plan B is fit on the crank gear and replace the cam gears to accept the wider belt,but I don't really want to do all that.
PostPosted: Thu Jun 16, 2016 6:47 pm
casting on the mk1 head is different, in the thermostat region, you need to plug a coolant hose, and swap all mk2 timming components, covers,brakets pulleys ect
swift 2000
megasquirt efi
rx7 460cc injectors
td05h-16g @ 18 psi
cusco 1way LSD
PostPosted: Thu Jun 16, 2016 7:46 pm
@bostsgt- Thank you very much for the info. This explains a lot, much appreciated.
