It is currently Thu Jan 18, 2018 7:26 pm
 Post subject: NO START
PostPosted: Mon Sep 12, 2016 8:44 pm
:evil:
Hello everyone...
Over a year ago my 1999 Swift blew a head gasket, and after that repair my piston rings failed.
NOW
I've finally sent the head to be rectified, got a new timing belt, pump & crank sprocket
The Fuel pump has been replaced
The sparkplugs have been replaced
I have compression (new piston rings)
Replaced the MAP sensor
NOW, no matter what i try, the car wont start
I'm running out of options,
the Crank sensor reads 412 ohms
the Cam sensor reads 810 ohms
and the Timing reads 5 degrees Advance
According to my scanner... there are no faults
I need help
 Post subject: Re: NO START
PostPosted: Tue Sep 13, 2016 4:04 am
If you put a gasket on the oil pan, that will cause this symptom. It spaces the crankshaft sensor too far away from the crank sprocket. Use RTV only to seal the pan.
PostPosted: Sat Sep 24, 2016 4:00 pm
I did use RTV
8)
PostPosted: Sun Sep 25, 2016 6:39 pm
:confused:
Hello everyone...
I have a 1999 Suzuki Swift with a 16 valve, 1.3L, MPFI system
I had rebuilt the engine after the rings had failed (shortly after buying the car)
The car had sat in the driveway for about a year before I got it all back together.
NOW the car wont start after I changed the timing belt.
I got it in TDC, i made sure all the valves were closed on the #1 cylinder
I got it with the Cam-shaft in I (intake) first, all it did was back-fire
I changed it to E (exhaust) with a new're timing belt (just in case the previous one had stretched to much)
The spark-plugs have been replaced
It seems as if there is a very low amount of fuel because its like the engine wants to start and its drowning for fuel and/or if it was out of time (but i've checked that about 100 times)
I need help
There must be something i've missed and due to the anger I'm getting I might have missed it...:mad: :huh:
PostPosted: Sun Sep 25, 2016 6:43 pm
Engine backfire is caused by an imbalance in the air-to-fuel ratio of the vehicle. Backfires occur in one of two places. A backfire in the intake manifold is caused by a ratio that is too lean (not enough fuel). A backfire out of the exhaust system is caused by a ratio that is too rich (too much fuel).
PostPosted: Mon Sep 26, 2016 5:49 am
Your plug wires are on wrong.
PostPosted: Mon Sep 26, 2016 6:14 am
nice catch woodie
PostPosted: Mon Sep 26, 2016 6:16 am
good eye, woodie. :wink:
PostPosted: Mon Oct 10, 2016 7:48 pm
Thanks for the advice...
I lined up the timing on the #4 cylinder and changed the spark-plug cables and the car started!!! :alien:
Its the little things that one overlooks that make big problems!!! :lol:
NOW :buzz:
It seems as if it wants to kick down the revolutions on park BUT remains idling a little under 2000 RPM's, it doesn't happen while driving...
What sensor could I be checking for this little problem???
