It is currently Wed Oct 18, 2017 1:29 am
PostPosted: Tue Oct 11, 2016 2:39 pm
Hi everyone. My gti refuses to start from cold unless I advance the timing to full advance on the distributor. Once the car is started and getting warm I return the timing to near stock. Once fully warm starting is easy. I've read other posts on the topic but none match my case. I'm no mechanic, I just tinker here and there. The car has a few mods: 60mm tb, oil catch can, cultus headers, 2"exhaust, lightened under drive pulley. I'm using the stock chip now (was using Tom's 11) so I can add a lil nitrous. Those with knowledge/experience please help.
PostPosted: Thu Oct 13, 2016 10:49 pm
It sounds like it could be the Electronic Spark Advance system at startup. I would run through the standard series of test to make sure your ECM is in good operating condition. Considering you have messed with the ECM that is definitely where I would start.
No codes?
Also make sure your water temperature sensor and air flow sensor are working correctly.
PostPosted: Fri Oct 14, 2016 4:57 am
good call!
i had a no start situation this summer that turned out to be an out of range coolant temp sensor.
PostPosted: Fri Nov 04, 2016 5:27 pm
Problem solved. Turned out to be faulty wiring coming from the distributor.
PostPosted: Sat Nov 05, 2016 2:07 am
Which most likely is part of your spark advance system. Glad you found it.
