It is currently Thu Jan 18, 2018 1:03 am
PostPosted: Fri Oct 14, 2016 8:59 am
Hello, I recently rebuilt the old 1.0 engine in my 1994 geo metro & I noticed oil plugs on either side of the oil pump. Is it possible to connect hoses to these ports & run the engine oil through the transmission cooler in the bottom of the radiator? This is on a manual transmission vehicle, thanks.
PostPosted: Fri Oct 14, 2016 7:20 pm
Why do you have a transmission cooler on a manual transmission? While it is possible I would buy the fairly cheap oil relocator kit and run an actual oil cooler up front if needed.
PostPosted: Sat Oct 15, 2016 5:28 am
I've heard it said that the automatic transmission cooler is too restrictive to use for engine oil. Don't know if that's a fact, or if it was just conjecture in a "what if?" kind of thread, but the fittings are smaller than what you would normally see on an oil cooler.
PostPosted: Sat Oct 15, 2016 5:41 am
This is where I read that: http://geometroforum.com/topic/5875212/1/
