It is currently Sun Jan 21, 2018 11:44 pm
PostPosted: Mon Oct 17, 2016 10:53 pm
Hey just wondering if anyone could please give me some ideas on what possibly could be wrong.
Recently brought a 92 mh barina when buying the car the guy told me i needed to change the fuel pump , which thankfully i did as there was exposed wires, anyway after pump change an fuel filter change etc we proceeded to start her up , fuel in carby an good ole start your bast**d.. had her running but then she just decided to keep dying on me has half a tank of fuel in her so its not that haha once warm stays on but the revs are all over the place , an when i turned it off today she shuttered an delayed in turning off ,please any advice would help me an be greatly appreciated.
cheers sky . :D
File comment: engine bay from previous owners pics on here :)
PostPosted: Mon Oct 24, 2016 8:52 pm
hi sky101, it sounds like you have a few problems,
first the carby is one of your problems, the 2nd, your timing is out,
I would recommend replacing the spark plugs if needed, and adj your
tappets, and replace the timing belt.
as for the running on problem, there is a fuel cut off switch in the carby,
witch should stop fuel flow to the motor, and there is probably carbon
build up in the combustion chamber that might be causing it to diesel on.
and welcome to the forum :)
PostPosted: Thu Nov 03, 2016 3:34 am
Thanks so much really appreciate it !
I recently got the carby rebuilt , because it was buggered from sitting for so long (this was done professionally)
I put it back on all lines connected properly took photos an have great memory but im unsure on how to do the a/f mixture he said he wound this screw in 3 turns . She started an idled after a few tweaks on the idol screw but now is revving too high an is this because I haven't adjusted the a/f ? An we did tinker with the timing an it says on bonnet 6 degrees BTDC an that were we put it back to . (Checked timing belt still all good)
Cheers sky
PostPosted: Thu Nov 03, 2016 7:53 am
hi Sky101,
I might be wrong, but when you redid the air lines, did you connect air line to the back bottom of the air cleaner?
the other thing is, when your carby was built did the builder recalibrate the auto chock? it might be going
to the third position on the high idle.
