http://www.teamswift.net/
Ticking noise?
http://www.teamswift.net/viewtopic.php?f=22&t=62655
Page 1 of 1
Author:  Swift sensation [ Fri May 19, 2017 10:08 am ]
Post subject:  Ticking noise?
My 89 GTI makes a ticking noise while it's running! Do I need a valve adjustment?
Author:  Rustyoid [ Fri May 19, 2017 10:19 am ]
Post subject:  Re: Ticking noise?
Your engine has hydraulic lifters. It is common for them to become dirty and the check valve gets stuck. You can take them apart and clean them, or replace them. There are guides taking them apart on the forums.
I have had success cleaning them with ATF. Drain your engine oil and fill the crankcase with ATF. Let the engine idle for 2-3 hours. Drain the ATF and refill with regular oil. Let it run for a few minutes then drain again to remove any remaining ATF. It does not work all the time, but I have had success cleaning my 3 cylinder lifters this way.
Author:  DTM GTi [ Fri May 19, 2017 11:00 am ]
Fresh oil and filter would probably fix that :mrgreen:
http://www.phpbb.com/
