It is currently Sat Feb 24, 2018 1:28 pm
 Post subject: No power... at all?
PostPosted: Sun Jun 18, 2017 9:55 pm
Hi! I just got a 1985 Swift and got it up and running.
It looks like the radio wire from the accessory on rail shorted out on something..
Now there is absolutely no power to anything. The battery has 13V strong coming out of it but nothing is getting any power at all.
I checked all the fuses in the fuse box under the steering wheel and they are all good
Is there some other fuse box or master fuse i am missing?? I can't seem to find anything anywhere
Anything helps!!
 Post subject: Re: No power... at all?
PostPosted: Mon Jun 19, 2017 12:20 am
Fuse box under the hood driver side.
PostPosted: Mon Jun 19, 2017 2:28 pm
Uhh am i missing something??
I cannot find another fuse box anywhere
PostPosted: Mon Jun 19, 2017 8:32 pm
My mistake. I misread the year. See fusible link from battery in this picture Lihtan/mk1/88%20carb%203%20cyl%20MT%20wiring%20diagram.png
PostPosted: Tue Jun 20, 2017 2:55 am
That is an amazing diagram! Thanks!
Hopefully that fuse is still there will all the.. questionable stuff prior owners have done..
The radiator fan was run off a single 22 gauge speaker wire that went directly from the battery, through the wire into the cabin with a rocker switch, back to the fan wire..
PostPosted: Wed Oct 11, 2017 3:26 am
Yikes! No fuse block??!?
Yeah, you may want to invest in one of those. Check Craigs List for parts. Not sure it it would work - or even fit - if you got one from a newer 90s Metro, but who knows... maybe you'll get lucky.
Users browsing this forum: Google [Bot] and 2 guests
