It is currently Wed Feb 21, 2018 4:00 pm
 Post subject: Swift GTI-89
PostPosted: Mon Oct 30, 2017 4:41 am
Hi!! My Swift GTI wont start when the Engine is Cold sometimes...when i add a Little starting-gas i can get it to run?? and then it will start perfectly untill the next time the Engine is Cold....
 Post subject: Re: Swift GTI-89
PostPosted: Mon Oct 30, 2017 5:57 am
my twincam had a similar condition. it had a coolant sensor (clt) that was out of range and the ecu wouldn't apply the proper cold start fuel enrichment.
when the coolant heated up a little bit the sensor would fall into range. it would start normally then as long as the engine was warm.
PostPosted: Tue Oct 31, 2017 11:13 am
Does anyone know what color it is on the cables to the tempsensor?? I think they maybe switch the connector to the sensor on the intakt manifold??
