It is currently Thu Feb 22, 2018 10:10 am
PostPosted: Fri Apr 30, 2004 10:44 am
Hi!
I have change my front lower control arm (brand new) and my shock for both passenger and driver side.
But I have bad handling with my passenger side. When I drive I ear some "clock" sound when I pass on little street hole.
What could it be ?
thanks.
PostPosted: Fri Apr 30, 2004 5:30 pm
I had worn swaybar bushings that gave me the same noise.
2009 Cannondale Rize
PostPosted: Fri Apr 30, 2004 6:22 pm
Ok thanks.
I have new bushing link kit for my sway bar, it's 2 little bushing with 3 washer for each side.
But I don't know how to install it. When I try to remove the old one, I can't remove sway bar to the lower control arm. How can I replace this bushing kit ?
And do I have to change the bigger one bushing conect to the floor ?
Thanks for your help.
PostPosted: Sat Jun 05, 2004 10:05 am
Ok I change the swaybar bushing and link kit and know is like new. No more sound from the front, thanks you.
Pat.
PostPosted: Wed Jul 15, 2015 4:45 pm
By chance was this noise also felt on the flooring of the front as in where your feet rest as your drive? Im getting some noise too and have a feeling it may be the sway bar bushings.
Thanks
PostPosted: Fri Jul 17, 2015 12:34 pm
I have the exact same problem. Swaybar bushings sounds like part of the solution. What about changing tie rod ends?
