It is currently Sat Oct 21, 2017 3:27 pm
 Post subject: sunpro tach
PostPosted: Tue Mar 22, 2005 4:17 pm
i have a 2" sunpro tach that was working fine intill i took it over 5,000 and the light quit working so i checked the conections and started the car the light came back on but as soon as i took it over 5,000 again it quit intill i turned the car off and on again.
So dont buy sunpro gauges!
1991 swift GT and i only payed $50!!!
2004 nissan 350Z
PostPosted: Tue Sep 27, 2005 8:57 pm
I installed a sunpro super tach II this sunday and just now got it working right. The ecu tach signal's impedance was too high so i had to add a second input buffer transistor to make a darlington pair. Even then the tach was reading low and i had to adjust the trimming pot. While the mods required to make it work were only around $5, I don't think many people would know what to do. It is possible to make this tach work but I wouldn't recamend it unless you know a good but about electronics and have alot of patience.
PostPosted: Wed Sep 28, 2005 1:49 am
Your car has the distributorless ignition, right? There was discussion on installing tachs on vehicles with DIS in this thread:
http://www.teamswift.net/viewtopic.php?t=11040
PostPosted: Wed Sep 28, 2005 2:24 am
Thanks for the link but I had already read that thread. None of the methods mentioned in it would work with the sunpro tach, but I got it working using the ecu tach signal and the methods I mentioned above.
