It is currently Wed Oct 18, 2017 4:15 pm
PostPosted: Sat May 07, 2005 1:20 pm
I recently installed the SSGTi.com stage 2 chip. For reference I have a 1994 Swift GT (CA emissions) w/AC.
I am very pleased with chip. I anticipated some negative side effects like engine check light or puffs of black smoke on high RPM shifts....nothing of the sort.
It performs great! I have noticeable power increases in every gear. I no longer need to downshift to maintain momentum on inclines. This chip makes my US spec Swift pull like the MK2 GTi I had when I lived in England...better actually.
I simultaneously installed the SSGTi.com rear engine mount. Good thing too because with the added punch of the chip, my motor was likely to jump out of the bay!
I anticipated some interior noise as I have fittied hard mounts to other cars. I used thin rubber gaskets to deaden the impact a little. Of course, there is still a noticeable "hum" in the car.
The mount was a good buy! Shifts are more precise and you just feel like the engine are chassis are one solid piece good product!
"Drive it hard, drive it fast...expensive aftermarket parts will make it last!"
- 1993 Suzuki Swift GT
- 2008 Golf R32
