It is currently Fri Oct 20, 2017 4:31 am
 Post subject: cam gear +10
PostPosted: Sun Aug 14, 2005 3:15 pm
well after two weeks of having the cam gear+10 in my car, only can say is that the rpm´s and throttle have increased considerably and idle also.
the car seems it has a new engine now and keep smiling by passing others cars.
it´s so much fun to drive now my 2001, 3cyl, N/A.
the changes were felted right away once i turned the engine on.
i´ve been reading so much about this product that i felted the need to try it out.
results right away. advise for all the sceptics........IT DAMN WORKS INDEED.ok??
only have to thank to MIKE, for his work and keep it up...... :thumb2: :thumbsup:
i can say now ..............I FEEL THE NEED ..........THE NEED FOR FUN.....
RF
PostPosted: Wed Dec 28, 2005 5:56 am
Thank you for the post.
Does this have any negative effects on passing emmisions? Will I see a increase in hc or co output?
I think I would like to try the gear out too. But as heads up prior to purchasing would be great!
Thanks in advance!
