It is currently Thu Oct 19, 2017 1:59 pm
PostPosted: Sat Jun 28, 2008 2:54 pm
Used it for 4600 miles, and finally changed it after 1 year. :oops:
Car: 87 Turbo Sprint, stock, A/C, cruise control
Driving: Light to moderate use; extreme temperatures hot and cold.
Result: No leaking seals as yet.
Conclusion: Have just put in fresh Quaker State Full Synthetic today. Satisfied it is a good product for the engine and turbo.
Suggest: Buy during their 'promotional periods', and it is quite affordable.
PostPosted: Sat Jun 28, 2008 7:27 pm
Finally! Liquid HP! :worship:
is that cheaper than Mobil and Castrol? havent seen it here.
looking for:
PostPosted: Sat Jun 28, 2008 7:59 pm
Normally sells for about $6 per quart here.
It can go as low as $1.50 if you get it with a rebate.
Nice stuff so far.
