It is currently Sun Feb 25, 2018 6:48 am
 Post subject: Synthetic Caliper Grease
PostPosted: Mon Oct 06, 2008 5:23 pm
Working on brakes can be a thankless job.
This grease is to lubricate the metal to metal contact points, and help prevent brakes from sticking due to wear and rust.
It was fairly inexpensive, and a tube lasted me a couple of years.
So far, it has lived up to it's expectations, and seems to stay put.
A little extra 'touch' which may help your brakes wear evenly, and thus last longer, I would buy it again.
Again, not a necessary item, but something which might set your brake jobs apart from the ordinary.
PostPosted: Mon Oct 06, 2008 8:02 pm
I use that stuff religiously on all brake jobs. When I got my 98, all the caliper slides and pads were seized in place. I cleaned them all up and lubricated and after 4 months, everything is still moving freely :D
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
