It is currently Wed Feb 21, 2018 10:20 pm
PostPosted: Thu May 23, 2013 5:19 pm
one of our members, fainya down in texas, performs service rebuilds on our cars' distributors.
i have had him do several for my twincam engines and a mk3 g10. as you know i can be pretty particular with my machinery and i generally spare no expense to do things correctly.
fainya's distributors exceed any specification i might have. i send him an oily lump and he sends me back a distributor that looks like a new unit. he disassembles the distributor, cleans it, bead blasts the case, inspects and polishes the shaft, replaces the bearing and shaft seal, checks the unit's curve, and reassembles it with a new o-ring and cap seal.
i understand that he also checks the mechanical advance mechanism, springs, and breaker plate operation and tests the vacuum advance pots on the older distributors.
he charged me a basic rate of $50 which included return shipping. in case you don't recognize the value of that fee, a new distributor costs over $300 and a reconditioned distributor is usually over $200.
i highly recommend this service for any distributor with over 80k miles or older than 10 years. the twincam engine i just put together for my white gt got a fainya rebuilt distributor and it runs like a swiss watch. send him a pm. :wink:
PostPosted: Sun Jul 07, 2013 8:32 am
I could not find fainya, on this site. I would like to contact him. Can you help T3?
PostPosted: Sun Jul 07, 2013 1:35 pm
memberlist.php?mode=viewprofile&u=8156
image_id: 22616
1993 Swift Gti
PostPosted: Fri Aug 09, 2013 8:58 am
highly recommended, fainya has a bunch of very satisfied customers.
viewtopic.php?f=17&t=56296
PostPosted: Fri Aug 09, 2013 10:38 am
Count me in as a very happy customer too!
Thanks to fainya for his fantastic workmanship... cheap labour... quick turnaround... and especially, it's noticeable perk to my G10 (I thought my dizzy was fine). Thanks to GeoGlenn too for finding me a core & vac pots saving me lots of shipping.
'91 Vert... Rebuilt 1.0, Clutch, KYB GR2 Shocks, Control Arms, Tie Rods, Motor Mounts, Wheel Bearings, Black Topper, 14" LuxAlloy Wheels, Bad Red Paint
PostPosted: Fri Jan 10, 2014 11:03 am
love the killroy
PostPosted: Sat Jan 03, 2015 8:25 am
I have a Distributor from Fainya. It is running like a clock. Thanks T3 and thank you Fainya!
