It is currently Mon Mar 19, 2018 3:38 pm
PostPosted: Tue Jan 27, 2015 7:22 am
I use my Geo to run around the country to aquire transmission cores, distributor cores and engine core for rebuilding.
With my Geo suspension lowered one inch and wide 15" tires, I was rubbing on bumps the rear tires. This was with 5
transmission cores and a 1.3L short block in the back of the Geo.
I have now installed the AirLift kit that there tech support suggested I use. ... EBIDX%3AIT
It took more time to run the air lines then install the air bags into the springs.
I am happy with what this kit did for me. 5 psi to keep the bags inflated inside the rear springs. 35 psi and the rear of the car
rides up 2 inches higher.
2907 airLift kit installed. I ran the fill nozzle up into the gas cap area.
PostPosted: Thu May 28, 2015 10:02 pm
Is there a way to do this on the front also. I want to cut my coils so I can "sit low" but I want to hook it up to a small compressor to blow them up and drive around "comfortably"
1993 Geo Metro LSi
1994 Toyota Pickup
My Car Club Website. Check out Videos of my Swift and all the other Cars in my Club.
