It is currently Sat Oct 21, 2017 8:30 am
 Post subject: how complicated is it
PostPosted: Wed Aug 17, 2005 10:35 pm
how hard is it to do the geo metro 3 cyl. to swift gti engine conversion
PostPosted: Wed Aug 17, 2005 11:03 pm
number one!
Not hard, just takes time. A lot easier if you have a GT donor vehicle. Read all you can on it, it's been covered quite a bit here.
PostPosted: Wed Aug 17, 2005 11:07 pm
Impossible.
There are MANY MANY posts in the CONVERSION topic. Spend a few hours and see what others have found.
<img src="http://tellico.off-road.com/wwwthreads_uploads/1438321-lolsroyce.gif">
PostPosted: Wed Aug 17, 2005 11:11 pm
also depends on your own mechanical skills. but as mojo says, the :search: function will take care of most your questions .in the end it is well worth it. and welcome to the board!! :D
Dattman wrote:
PostPosted: Thu Aug 18, 2005 12:35 am
hey tuff do you know if you have to swap trannys and all that other good sh&*
PostPosted: Thu Aug 18, 2005 1:41 am
You'll be swapping: engine, tranny, drive shafts, brakes, wiring harness, ECU, fuel pump. You may also have to fabricate the odd engine mount or two, plus spending a few days swearing at rusted bolts and pulling your hair out over the wiring. Sounds like fun. :twisted:
PostPosted: Thu Aug 18, 2005 5:38 pm
i swapped a g13b into my 92 metro vert and kept my 4.39:1 transmission from the 3 banger and my vert brakes. all i did was swap in axles from a SOHC metro sedan. i had to use most of the bits from the twincam engine - motor mounts were the same as the SOHC metro sedan's, radiator and hoses, intermediate drive shaft, shifter linkage, engine bay wiring, fuel pump, etc.
