It is currently Tue Oct 17, 2017 4:07 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 15, 2006 12:16 am
The links for the pictures are dead, could anyone that has then post them back up please. I would love to see them.
 Post subject: hey
PostPosted: Fri May 25, 2007 1:56 pm
did anyone ever try this? I would like to know how it worked out.
PostPosted: Wed Jun 20, 2007 5:40 am
Certified (nuts)
The Opel Corsa 1.0L or 1.2L is a DOHC head 3cylinder which may fit the G10.
PostPosted: Thu Jun 21, 2007 9:53 pm
hmmmn but the ecotec system would have to be removed and thats quite a bit of hassle im told, people remove it on the 1.6s
PostPosted: Tue Jul 03, 2007 12:09 pm
:roll: Will it fit straight in..... It seems to have a coilpack unit 'monoblock', a la SAAB. Anyone have the full spec??
"Corsa now benefits from fuel-saving TWINPORT engines for both the 1.0 litre 12v three- cylinder.
Fuel consumption is considerably reduced through the employment of a variable intake manifold and high exhaust gas recirculation rates.
Its smaller 1.0 litre 12v brother was already one of the most economical petrol engines around. With new TWINPORT technology even less fuel is consumed, returning 53.3mpg on a combined cycle. At the same time, TWINPORT also promotes stronger power delivery (Eh??)"
Anyone any thoughts........
BBJohn :clown:
"Life is not a dress rehersal"....so I am told by those who don't believe in reincarnation!
 Post subject: Corsa X10XE Spec sheet
PostPosted: Wed Jul 04, 2007 3:24 pm
8) I got this content from the Opel dealer site.....
Engine Data: Z10XE
Engine, location >> front, transverse in front of axle, 7deg fwd inclined.
Cooling system >> with liquid, sealed circuit
Cyl, no >> 3
Bore(mm) >> 72.5
Stroke (mm) >> 78.6
Displacement (cc) >> 973
Comp ratio >> 10.1:1
Engine, type >> in line, 4 main bearings
Cyl block/head, material >> cast iron/aluminium
Camshaft(s), location >> 2 overhead (DOHC), driven by chain
Valve train >> roller rocker with hydraulic bucket tappets
Valve arrangement >> V : 4 per cylinder
Valve adjustment >> automatic – hydraulic
Fuel system >> seq MPFI, Motronic ME 1.5.5 hybrid
Ignition system >> electronic, ign map, ign coil direct-to-plug
Output(HP)@5600 >> 58
Max torque(Nm)@3800 >> 85
This NOT correct (even for Opel!!) the service suppliers list a toothed belt for the X10XE – unless the Z10XE is different with chains… don’t see that much reengineering myself??
Still.... Is it worth having a go a fitting one??
BBJohn
:clown:
PostPosted: Thu Jul 05, 2007 4:25 am
Certified (nuts)
The one I saw was definately chain driven cams. 99' or 00' model.
PostPosted: Sat Jul 07, 2007 6:40 am
:thwack: Ahh yes......
A quick look on Ebay turned up a 'chain kit' for the Agila 12v 1.0&1.2.
So, then, does anyone know if a Vauxhall 3cyl is a Suzuki 3cyl (G10) with 12V - and will it fit??
BBJ :?:
PostPosted: Thu Sep 06, 2007 6:44 pm
It's this one right?
I think I have a few more.
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu Sep 06, 2007 7:45 pm
The Smuggler
What is that engine in?
And I love this one!
PostPosted: Fri Sep 07, 2007 1:52 am
:shock: what photo's or twincam 3 cyl engines???
It looks like it's in a mk1 swift :razz:
PostPosted: Fri Sep 07, 2007 6:58 am
:thwack: I spent an hour looking for the rest of the pictures but coudn't find them. I know I have them and I've seen them (saved on a cd somewhere). I know there is even one where you can view the complete car with an open hood. I'll keep looking for them today.
Knuckles, I think it was a Forsa (mk1 swift).
Dattman, I know I have pictures of that particular engine, just can't find them yet.
2003-EVO7 GT-A
PostPosted: Fri Sep 07, 2007 7:38 am
Certified (nuts)
Just to stop you banging your head off the wall instant shine!!!!
http://www.teamswift.net/viewtopic.php? ... iego+moran
MK1 it guys! 8)
PostPosted: Fri Sep 07, 2007 9:10 am
MK1 it guys! 8)
:lol: Yeah, that's it! Thank you.
But if IRC I think there are a few more pics available / somewhere.
2003-EVO7 GT-A
PostPosted: Thu Sep 27, 2007 1:21 pm
wow
alto have a 1.0 block with 4 cyl which is a g10 engine similar to g13a
Does anybody have info what stroke and bore is that engine ? it makes 68 HP which is not bad ,, nearly the same as g13 a could put a gti head on it :lol:
http://picasaweb.google.com/summitsvift
PostPosted: Fri Sep 28, 2007 2:33 pm
Yes apparently it's a destroked g13b, I've been trying to find one but no luck so far, thanks for the photo :razz:
PostPosted: Fri Sep 28, 2007 5:31 pm
swifterrr wrote:
wow
pretty sure they run a K10A engine....
:oops: or maybe a F10D
A K10A would be more fun though...
PostPosted: Sat Sep 29, 2007 3:38 am
demomike wrote:
swifterrr wrote:
wow
no mate the new one does the old alto had a destroked g13, had it in one car magazine but can't find it now , does anybodody have a alto 99 manual ?
PostPosted: Fri Sep 17, 2010 5:42 pm
I know the owner of the G10 twin cam 12 valve. He is from Quito Ecuador, he cut the G13 cylinder head to suit the 3 cyl. Also placed 2 geo metro 1.0 cams in order to work the same way 3 cyl. It is a wonderfull car. It is a swift mk1 also named suzuki forsa GA. I think it has almost 95 hp with modified camsm lifters, valves, pistons. Double weber
PostPosted: Tue Sep 21, 2010 7:21 am
Thats alot of effort for so little power.
PostPosted: Tue Sep 21, 2010 3:08 pm
I would take that effort if I had the skills and equipment for it :mrgreen:
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
PostPosted: Tue Sep 21, 2010 7:38 pm
100hp from 1L is "little" ?
PostPosted: Tue Sep 21, 2010 9:27 pm
The Smuggler
I think its unique and kool!
regardless of the Little HP
PostPosted: Wed Sep 22, 2010 1:38 am
yahuarcocha 500 this weekend, good luck diego if you run!!
Find me on Facebook
My eBay link
Check out my videos
