It is currently Sat Oct 21, 2017 10:51 pm
PostPosted: Fri Apr 21, 2006 7:18 pm
does anybody know if a j20 motor will fit into a swift and if so do you have any example of pics cause its hsould be quiet the power plant.
PostPosted: Fri Apr 21, 2006 8:03 pm
Mama Said Knock You Out!
Ok... I'm really getting sick of seeing this exact same post over, and over, and over, and over... "Can (insert engine here) fit into a swift?" The answer is no. Unless it's a Suzuki G16, G13, or a G10, no, it won't fit. But, here's the killer.. You can make it fit! All you need is experience welding tubular steel frames, modifying drive axles, fabricating angle brackets, mounts, and other adapters, and a very very good knowledge of automotive electronics... Here's an idea. Go find a (insert motor here), measure it, measure the transmission, measure the vehicle mount positions, axle lengths, and all that good stuff.... Then, measure the engine compartment of a swift, and take note of the mounting positions, clerances for things like the steering rack and brake booster.
We'll make an example of this post
THERE IS NO DOCUMENTATION ON THIS FORUM THAT EXPLAINS HOW TO ADD ANY MOTOR TO YOUR CAR OTHER THAN A SUZUKI G SERIES ENGINE.
So.. If anyone does decide they have the skill to get'r done, rather than ask the same questions over and over again, please... document it, photograph it, and post it. I'll make it a sticky.... Just like this one.
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Sat Sep 16, 2006 10:30 pm
So is that a no on the j20 then?
:lol:
PostPosted: Mon Sep 18, 2006 4:40 am
Don't forget to read this trainwreck of a thread:
http://teamswift.net/viewtopic.php?t=19956
 Post subject: Ecotec in a Metro
PostPosted: Sat Feb 17, 2007 1:29 pm
do u think a 2.2 liter ecotec dohc gm 4-cylinder in a metro would be downright sick or what? I've been thinking about putting one into my 2001 LSi or a hatchback:twisted:
PostPosted: Wed Aug 15, 2007 11:23 am
i totally agree with GeoZukiGTi, No Motor Can work Better Then G series in Swift. G16a Carb ( Big Carb ) and With nitrous will Bring Up some good Power.
Rebuilting My GTti, The KiCk @$$ Machine... Ahsan GT.
PostPosted: Wed Aug 15, 2007 4:28 pm
please refrain from publicly agreeing with geozukigti.
it makes his head swell up bigger than the time he dropped that engine on it. :lol:
PostPosted: Thu Aug 16, 2007 7:44 am
HAHAHA, you said "swell" :lol: You'd like that wouldn't you :-P
PostPosted: Mon Apr 28, 2008 4:32 pm
I'm a tool! Not only did i put one in my swift i turbod it, and can't make a post on how it's done. It fits. I have pictures of it in the gallery. Just search for my name in there. A j18 and j20 fits in a swift, and must use j18 tranny and u can use the gti axles with a little mod. I'll post a write-up on it soon
PostPosted: Sat May 24, 2008 7:09 pm
still wating on the write-up.... :mrgreen:
PostPosted: Tue May 27, 2008 11:24 pm
if i buy a spaceship can i do an engine swap into my geo using tooth picks and bubble gum?
rollin' deep!
PostPosted: Mon Jun 02, 2008 11:01 am
YES!! Just make sure you call MacGuyver first :lol:
PostPosted: Thu Jun 05, 2008 11:58 pm
I am McGyver and do you know what i will do, i bet youll be shocked, i will proove what can be done in a situation like this in the ultimate emergency situation.
Remove the water resovoir top cover.
Soak that cardboard in the water
Make sure it gets very soft
Than squees it, to remove all the water
Than use it in you know where.
PROBLEM SOLVED BY TWIFTGTI
PostPosted: Sun Jun 08, 2008 2:34 pm
:lol:
PostPosted: Mon Sep 15, 2008 5:48 pm
owned!
PostPosted: Wed Jan 28, 2009 4:00 pm
Does this count?
1993 Metro XFI w/ Turbo Buick V6
9.27 @ 154
1992 Metro daily driver
PostPosted: Wed Jan 28, 2009 4:17 pm
Metro SS wrote:
Does this count?
DAMN !!! =)
PostPosted: Wed Jul 22, 2009 2:27 pm
thats what u call a mad metro, any build pics? that i would b interested in doing.
ive been toying wt putting the v6 vitara into a sedan swift
wish i had a car like runbag, wonder if he would help me build 1?
PostPosted: Fri Jul 24, 2009 4:27 pm
He posted build pics on here a while back. Look at his older posts, you'll find em! :D
PostPosted: Mon Aug 17, 2009 8:57 pm
i thought about dropping a DOHC 6G72 in mine.....until i measured the engine and found it about 12" wider than the engine bay in the swift. :lol:
next measurement will be on a VR6
im still considering putting one behind the seats. build my own shogun using a 350+ HP mitsu V6.
98 swift 1.6 16v swap
03 cobra bolt ons
too many others to list
PostPosted: Fri Aug 21, 2009 10:45 pm
WHAT TURBO BUICK MOTOR DID YOU USE? WAS IT ORIGINALLY A TURBO MOTOR LIKE A GRAND NATIONAL GNX OR WHAT? I HAVE A 3800 SUPERCHARGED I WOULD BE WILLING TO DROP IN, CURIOUS AS TO WHAT YOU DID FOR SUPPORTS/TUBE CHASSIS.
------------Educated Redneck------------
RIP-91 geo metro lsi convertible 1.0 liter 5speed
I TOTALED A 05 EQUINOX WITH IT! HEAD ON!
- 84 K5 Blazer, 12 inches of lift on SS 44's
- DD: 99 F150 4.6L V8 Ext. Cab, Longbox
