It is currently Fri Feb 23, 2018 5:39 am
PostPosted: Thu Nov 08, 2007 4:00 pm
Hello,
The whole point of this is:
I am trying to roughly calcualte without having the parts the compression ratio of a stock G13B 1.3 Swift GTi bottom end with a G16B Baleno 1.6 16 Valve head.
Has anyone done it?
I downloaded this to help... http://www.virtualengine2000.com/index.htm
Is a little bit hard without all the measurements.
In theory it should be a lower compression ratio as the G16B has bigger combustion chambers.
Cheers,
Damian
90-92 = 69 Alfa Romeo 1750 Berlina
92-94 = 80 Toyota T-18 SE
94-95 = 94 Suzuki Swift GTi
95-96 = 95 Suzuki Baleno GS2
96-01 = 96 Suzuki Baleno GTX
01-02 = 01 Peugeot 206 GTi
02-04 = 02 Peugeot 307 HDi
04+ = 00 Suzuki Baleno GL TURBO
PostPosted: Thu Nov 08, 2007 4:06 pm
The larger combustion chamber in the G16 is mostly beacuse of a difference in piston head. The G16 pistons have a dish.
I should make some calculations, but I am quite sure that a G16 head on a G13 block will result in higher compression ratio due to G13B pistons being flat. The absence of the dish will lead to a higher compression ratio than the one seen with G16 pistons.
PostPosted: Thu Nov 08, 2007 4:11 pm
Ok, I did my numbers, and CR will be ~10.5
PostPosted: Thu Nov 08, 2007 4:22 pm
Thanks Caaarlo,
What about a G13B bottom end with:
standard rods, and 75mm bore standard Baleno pistons with the Baleno 16V head?
Whats your best guess / estimation?
Thanks 8)
PostPosted: Thu Nov 08, 2007 5:20 pm
around 8
PostPosted: Thu Nov 08, 2007 5:32 pm
I calculated it a while ago, and think I got 11.6-1.
I'll have to look at the numbers again.
PostPosted: Thu Nov 08, 2007 8:06 pm
I have re-checked the calculations:
G16B Total Chamber volume = 46.76cc
The dish on the 71C50/51 pistons has around 12,56cc
So, the new chamber volume with flat top G13B pistons will be 46,76 - 12,56 = 34.2cc
New compression ratio with a 34.2cc chamber volume = (34.2 + 324.5)/34.2 = 10.48
These calculations are based on my previous dish calculations http://www.teamswift.net/viewtopic.php?t=24954&start=12
PostPosted: Fri Nov 09, 2007 12:14 am
I'll have to dig up that paperwork again.
Maybe it was 10.6-1 :huh:
Or maybe I'm :screwball:
PostPosted: Mon Nov 19, 2007 10:26 am
Yup.
I checked. It is 10.6-1
PostPosted: Mon Nov 19, 2007 11:23 am
Now you owe me a beer.
PostPosted: Thu Oct 22, 2009 8:40 pm
Caaarlo,
Are you able to calculate what my current Baleno G16B engines CR would be would be if I were to put a standard Swift GTi twin cam head on it? Please bear in mind I had custom pistons made for the Baleno which result in a CR of ~9.2:1 (instead of standard 9.5:1) with standard thickness headgasket and standard Baleno G16B head.
 Post subject: Re:
PostPosted: Sun Oct 25, 2009 9:49 am
I came up with ~ 11.0 when I did calculations, without counting the head gasket. I guess 10.6 is closer to reality. One of my friends wanted to do this for a while now, but after seeing such little gains in CR he decided to go turbo instead.
Suzuki Gold Master Tech
Users browsing this forum: Woodie and 1 guest
