It is currently Sat Jan 20, 2018 7:00 am
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jun 10, 2008 2:48 pm
Here's how they do it:
"also you need to convert the clutch to hydraulic using a toyota hiace van master cylinder mounted under the dash. "
PostPosted: Wed Jun 11, 2008 10:00 am
Tried searching that forum 8000 topics!
So they are using two master cylinders? One for the clutch one for the brakes??
PostPosted: Wed Jun 11, 2008 1:19 pm
Honestly I only know what I posted due to the fact I haven't attempted it yet. If you search for 4age or 4agze swap or hydraulic clutch you may find what you are looking for. I know the answer is there because I've read it. I haven't worked on my sammy in a long time due to a new project... Mazdaspeed Protege!!!
PostPosted: Wed Jun 11, 2008 8:49 pm
Um, yeah. It is a smaller seperate cylinder. Lots of cars have them, 1.6 swifts came from the factory with them, would be an easy setup if you could find one. Otherwise, you would probably want to grab the bracketry and pedal assy from under the dash of the donor car.
BTW, don't use hose clamps on this kind of system. The pressure in the line is similar to that of a brake system, so you will have to use adapter fittings and such if necessary.
PostPosted: Thu Jun 12, 2008 8:26 am
Haha I am aware of not using hose clamps. I have over 20ft of brake lines in all sizes, but I know what your talking about the little master cylinder for the clutch pedal. More work tonight, more pictures tomorrow or saturday.
PostPosted: Fri Jun 13, 2008 8:52 am
Got both top side mount tacked into place and the front tranny mount tackek. I had to tilt the motor slightly foward to get the axle outputs from the tranny to line up perfectly. Engine is held in by itself now and I need to reinforce frame rails that I cut and motor mounts.
PostPosted: Wed Jun 18, 2008 3:05 pm
Got some work done yesterday, but I didn't take pictures. Reinfoced drivers fraim rail and reinforced (3)motor mounts. There is a rear tranny mount that I might not have room to put in without cutting firewall.(which I dont' want to do) so for now the three are very solid and the engine moves as it would in its origional car. Dash is off car and engine wiring from metro removed and also the ECU. The rest of the wiring stays intact(air bag modules removed)
I have come to the conclusion that I SHOULD be able to pull the fork with the cable clutch. I was able to do with with little leverage.
I still need to convert the sephia shifter linkage over for proper function.
Axles cut and measured. Sleaving tonight.
Pictures for tomorrow
PostPosted: Thu Jun 19, 2008 8:38 am
V-Notched axles 6-8 times. plug welded holes. Bolted to car to see if they lock up.
PostPosted: Wed Nov 19, 2008 1:08 pm
Got a clutch master cylinder from a 280z and drilled a hole through firewall. Welded bar on clutch pedal and threaded end bolts to clutch master cylinder. Still need to run brake line, but car is on the ground and all I need is a new T8D ecu because I fried it due forgetting to connect a ground. once I get that it should start, not sure how long it will drive for, but I am going to beat the crap out of it and if something breaks its going to happen in the first minute.
PostPosted: Wed Jan 14, 2009 6:29 pm
any update?
PostPosted: Wed Feb 11, 2009 11:00 am
Just got a used ECU from a friend this weekend. Hopefully this weekend I should know if she will start or not. Also if she does start, I will jack her up and soo what happens when she goes into gear.
PostPosted: Mon Mar 30, 2009 1:05 pm
Started car up last weekend. Only running on 2 cylinders(hardly running). I blew one of the coil packs when the ecu went, should be set-up to try again within the next 2 weeks.
PostPosted: Tue Apr 07, 2009 11:00 pm
I thought the motor they put in the sephias was the mazda built bp motor, the same motor used in the proteges, miatas, escort gt's, mx3s, all those and some other jap cars
http://vids.myspace.com/index.cfm?fusea ... d=38221906
I would drive this Honda (engine) or put a GTi motor in it
PostPosted: Tue Apr 07, 2009 11:11 pm
just a variation of this motor
this was my other toy for about 2 years (it was free and I had less then 300 dollars into it with a good inspection)
PostPosted: Wed Apr 08, 2009 1:07 pm
True for sephia's before 1998. This motor came out of a 1998 and is a kia motor, not the mazda one. Still don't have my new coil packs or injector yet.
PostPosted: Wed Aug 26, 2009 11:42 am
Swap is dead, another day another time. Had car running but never drove, I believe the axles would have held up. Ended up taking a sludgehammer to them to try to break the welds and couldn't budge them. Selling car to my buddy for $500 . . .no control arm frame rust or rot(he needs one anyways and I have 8 cars). Putting good engine/tranny in car from a 1994 xfi I had sitting in my front yard.
PostPosted: Wed Aug 26, 2009 1:17 pm
Too bad. Good on ya for trying something like this though!
"daddy's car vroom vroom"
Mods coming...............
PostPosted: Wed Aug 26, 2009 2:34 pm
What ended the swap?
CJDavE wrote:
" Only qwall is thinking about what's in my pants."
PostPosted: Thu Aug 27, 2009 12:32 pm
I'll do something like this when I have the time to do it right. I have 8 car's right now and trying to get down to 3 by winter. By putting stock motor back in this one eliminates two cars. (i got a full 300zx vg30 with a bad body just sitting : ) waiting for me to do something with it.
