It is currently Wed Feb 21, 2018 11:53 am
 Post subject: 1.0 into a sami 4wd
PostPosted: Sat May 31, 2008 7:14 pm
I don't know if this belongs here, but this section seemed to be the closest I could find. If not please move or let me know where it belongs.
After a trip up to Lufkin area, I picked up a metro3 from Kinkie here on the board, Thanks for the deal, I needed this to continue getting ready for my rock trip in September.
I stripped the none essential items removed and then bolted it directly to the sami transmission, it works perfectly except for one small tab that needs to be removed for the starter to bolt up.
Doing this swap gained me a LARGE amount of room to move the motor forward so I can stack a second transmission (Ford T-18 w/ dana 20) transfer case behind my factory trans on a stock wheelbase sami.
I will continue to post pics during the process unless it is an issue with this site, it not being a metro/swift build. I am going to be getting the cam/ head econo package to hopefully accent the propane setup that I am installing on it. I am having the flanges made for exhaust and intake so I can custom make my own to suit my needs of propane and header design.
1988 sami- propane,bed lined interior, dual trans, twin stick d20, 5.125, locked F&R, YJs, MLs, 31X13.5 SXs, 1.0 3cyl swap now underway.
 Post subject: Re: 1.0 into a sami 4wd
PostPosted: Sat May 31, 2008 9:04 pm
I am having the flanges made out of 1/2" steel and was wondering if it would hurt anything to delete the EGR tube? I am not going to be using water tubes in the intake either, I am running propane and the mixer has its own water lines to simplify everything. Will it hurt the head to just block off the passages leading into and out of the intake?
PostPosted: Sat May 31, 2008 9:16 pm
Sounds like a cool project.
Keep us posted!
You should be fine blocking off the EGR.
PostPosted: Tue Jan 06, 2009 4:49 am
Im just finishing off my G10t swap in my 87 Samurai. It hasnt seen much street time, still shakin the bugs out but it seems like it rips pretty good.
heres some pics...
Think zuke.
PostPosted: Tue Jan 06, 2009 4:29 pm
Mama Said Knock You Out!
Cool swap! Did you have to do anything special with the electronics?
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Tue Jan 06, 2009 4:52 pm
Special? Not really, just made the engine harness/computer feel like it was still in the sprint... only a few wires to mess with.
Think zuke.
