It is currently Fri Oct 20, 2017 9:35 pm
 Post subject: Engine swap. PICS.
PostPosted: Sat Aug 16, 2008 3:07 pm
So, got half way done, I took off the wiring from both of the cars and about to install the ecm and engine harness, but I have a question. The chassis is 1994 and im putting in a 1990 engine in it. Does that mean I use a '90 engine harness and computer but use 94 wiring harness?
Ill post up some pics later tonight.
Thanks.
 Post subject: Re: Engine swap.
PostPosted: Mon Aug 25, 2008 3:22 pm
Mama Said Knock You Out!
use the full mk3 harness. It will plug into the engine just the same as the MK2 harness will.
TGstring wrote:
sooooo clean it's duuuuurrty.
PostPosted: Tue Aug 26, 2008 5:09 pm
i'm a stone cold, fearless, harness splicer. :twisted:
use whatever you have and make it work. if you use the mk2 harness with a mk3 chassis you only have to splice 2 connectors - one for the dash instrument cabling and one for the engine bay power, fuse and relay rack. all the spliced wire colors match between the mk2 and mk3.
the only tricky part is getting the coil and ignitor power and ground circuit spliced into the chassis wiring and that's only because there is a monolithic electrical noise snubber and a monolithic diode wrapped into the chassis loom.
if you keep the chassis wiring on a non-gt chassis, you also have to add the yellow wire from the oil pressure idiot light switch to the dash instrument cable connector.
PostPosted: Tue Aug 26, 2008 11:41 pm
mhm, well I just spliced the connector onto the engine harness. I was left with 2 extra wires that dont connect to anything.
one thing I dont understand is where does the SDL connector goes into. I cant find the right connector for it. And it seemed to easy to plug everything in, is it a trick thing to do or just find the right connector and plug it in?
PostPosted: Thu Aug 28, 2008 4:49 am
which side of the connector has spare wires and what colors are they?
PostPosted: Thu Aug 28, 2008 11:32 pm
mhm, not sure I have to check.
But this is the progress so far, got both of the engines off. the car is ready to have surgery! soon to put in the engine.
all is left after is to change all the brakes cause the GT ones are bigger and better :P. Should start. Still deciding on paint or whether I should just leave it as is.
haha sorry bout my before mistakes, posts and pm's. I was just a kid :P
here are some pics:
interior almost completed, swapped out the dash and wheel:
as it sits right now:
dropped the engine:
the new one waiting to be worked on, has amazing compression:
old one out:
i hope its ok to have that many pics :)
 Post subject: Re: Engine swap. PICS.
PostPosted: Sun Sep 21, 2008 3:41 pm
You have big balls...trusting two stacks of bricks to hold up your project car instead of jack-stands....and even bigger balls to do all the work in flip-flops.
the KUZUKI
PostPosted: Sun Sep 21, 2008 6:59 pm
I think you should leave it as-is. Looks really nice 4 different colors! :P
Nowadays driving an 85 GMC SIERRA is painful... maybe thats why I'm currently working on an 87 Sprint Turbo!
PostPosted: Thu Nov 13, 2008 1:43 pm
Im actually thinking of leaving it multi colored!
The car still won start, I used my friends maf sensor and still does the same thing as before.
Should I tear the car apart and just get a new a wiring harness from the '90 gt and use that?
will all the connectors fit where they are suppose to?
PostPosted: Thu Nov 13, 2008 2:42 pm
sweet engine stands chief
the lolcar family
PostPosted: Fri Nov 14, 2008 3:42 pm
thanks!
but anyone have any advice? please and thanks :)
PostPosted: Fri Nov 14, 2008 7:09 pm
sof220 wrote:
thanks!
yeah, dont chance your motors falling over =)
the lolcar family
PostPosted: Sat Nov 15, 2008 11:21 am
-_--- thaaananks lol
ripping apart the car again and replacing the wiring harness with an mk2 one.
Will all the connectors fit the m3 chassis?
PostPosted: Sat Nov 15, 2008 2:14 pm
dunno, but those bricks holding up the plastic bumper thats secured to the body via a few rusty bolts doesnt look very safe to be under
the lolcar family
PostPosted: Sat Nov 15, 2008 2:19 pm
seriously enough
that was just temporary, when I climb under i DO USE proper jack stands and stuff.
You wouldn't think people would have that much of a problem with that.
PostPosted: Sat Nov 15, 2008 2:50 pm
sof220 wrote:
seriously enough
well keep it up, boost that thing, youll have some fun :p
the lolcar family
PostPosted: Thu Jul 30, 2009 5:25 pm
hi i have a suzuki swift gl 4 door and a gti i want to take the d.o.h.c engine an put it in the gl witch has a s.o.h.c engine that has the same size engine block, it came to as an automatic car and i put a manual in it what whould i have to change to put the d.o.h.c engine in it does anyone know???
