It is currently Thu Oct 19, 2017 3:07 am
PostPosted: Fri Oct 17, 2008 11:05 pm
I just switched my '97 engine that was burning a quart of oil every 300 miles to an XFi engine (91?) that I had laying around. I didn't really have any problems, except that I now can't get the 'new' engine to run because the spark is intermittent. It is because the earlier engine doesn't have the crank position sensor?? There is an intermittent spark that will pop-off a couple of cylinders, but the engine won't run because the spark won't keep going. I tested it straight off the coil, and proved it was only going at first try cranking it around, then no spark. The dizzy cap, wires, etc. are all fine. Can the XFi engine control module be simply plugged into my later '97 car??
PostPosted: Sun Oct 19, 2008 5:34 pm
in a word - no, not simply.
viewtopic.php?f=30&t=34924&p=301123#p301123
PostPosted: Sun Oct 19, 2008 8:08 pm
arent there differences between distributors? theres a 2nd trigger on one of the 3 "lobes" that the newer ecu uses? check yours distributors
the lolcar family
PostPosted: Wed Oct 22, 2008 12:30 am
Time for more parts, or an OBD2 equiped engine. You'll need to add a crank sensor setup. Will require a good amount of parts from your other engine and get another oil pump. It's not advised to use a pump from a blown engine, but you can use all the other parts. Someone did a complete rightup first hand, but I don't remember who did it. Search around some.
Was it you T3 ragtop???
EDIT: viewtopic.php?f=22&t=40019&start=0&st=0&sk=t&sd=a&hilit=crank+sensor
Here is one of the rightups to swap OBD1 to OBD2. Applies to both 1.0 and 1.3
PostPosted: Thu Oct 23, 2008 3:36 am
Thanks guys, I think it will be the easiest thing to do simply to take the lower drive cog and crank sensor 'stuff' off my old engine, and put it on the XFi engine I put in the car, along with the alternator, water pump pulley, oil pump and whatever else ends up necessary.
