It is currently Fri Oct 20, 2017 4:29 am
PostPosted: Sat Nov 29, 2008 12:47 am
I found a great 92 motor and do not know if these will swap out....... or swap out easily........ will I have to modify anything? Both are standard transmission so that shouldn't be a problem..... should it?? Thanks for any info..........!
PostPosted: Sat Nov 29, 2008 2:15 am
i believe the 1L engines mostly stayed the same while the 1.3 changed drastically in the later years. wait for a reply from one of the experts.
PostPosted: Sat Nov 29, 2008 3:31 pm
here you go. :D
viewtopic.php?f=30&t=34924
