It is currently Mon Jan 22, 2018 2:02 am
 Post subject: Geo engine swap
PostPosted: Mon Jun 15, 2009 7:10 pm
I have a 95 geo xfi 3 cyl 5 speed good condition, I want to put it in my 96 geo same set up 3 cyl 5 speed anyone know if its pretty straight forward, or any differences? the only issue I have with the 96 engine is that it doesn't pass smog & burns oil.
p.s. sorry for the double post...
 Post subject: Re: Geo engine swap
PostPosted: Wed Jun 17, 2009 11:19 am
Your '96 has OBDII so all you can swap is going to be the block. You'll need your crank shaft position sensor and other stuff. Why not just get a compression test, Dry and wet, wide open throttle and see if it's rings or valves.Valves would be a head swap or rebuild and head gasket, I recommend 3Tech http://geometroforum.com/pages/heads. The re-ring can be done without removing the engine, maybe over a weekend.
You could try Seafoam a few times to see if it's a stuck ring but doubtful. The oil may be clogging the Cat. converter and O2 sensors. Start with a compression check.
Head Repair... http://geometroforum.com/topic/638797/1/#new
Have fun,
Bad Bent
