It is currently Thu Feb 22, 2018 11:06 pm
 Post subject: Econo Cam into G10T?
PostPosted: Fri Aug 07, 2009 3:58 pm
Hi guys,
before I go getting rid of these, here's what I have to play with for my Turbo3: Econo Cam & +8 & + 6 sprockets
What would happen if I put this cam and either of these sprockets in my G10T? Or if I slapped a +6 sprocket on a factory cam for my G10t?
Thanks :wink: ,
Ken
-Save the Trees, Eat a Beaver!-
91' Firefly Turbo Convertible -> '90 G10T Swap, +6 Timing Sprocket, Stock Turbo, intercooler & 198/330 Cam, NGK V-power's, 7mm wires, Boost Gauge, Manual Boost Controller set to 9psi, Mobil 1 & GM Synchromesh, Short Shifter, K&N + removed resonator, Gutted Pre-cat, 2" Exhaust, High Flow Cat & Muffler, Front sway bar, Front underbody Brace, 185/65R14's on Steelies..
 Post subject: Re: Econo Cam into G10T?
PostPosted: Tue Aug 11, 2009 2:32 pm
Not sure of the Turbo3 aspect but on most NA G10s the power band lowers and gas mileage can improve up to 6 mpg. That's "econo" and +10 cam gear. Most users advance the timing to 10+ BTDC.
That said my wife's '96 likes 8-10 BTDC and she still shifts at 3K but can drive with power down to 1500. Hope that helps.
Have fun,
Bad Bent
PostPosted: Wed Aug 12, 2009 5:01 pm
EconoCam + Turbo = No No
Suprfly told me, they say the worst cam for the T3 is the stock one, but really the EconoCam is the worst.
So the guy who grinds the cams really does not reccomend it.
My cars:
PostPosted: Wed Aug 12, 2009 8:33 pm
I stand corrected, thanks for the information. :D
Have fun,
Bad Bent
PostPosted: Sun Aug 16, 2009 9:45 am
yea, well I guess that answers it! Sold it to a happy customer anyhow, but I was curious :wink:
