It is currently Thu Oct 19, 2017 8:50 am
PostPosted: Mon Aug 17, 2009 12:54 am
I have ended up converting a n/a sprint automatic convertible. To a Turbo manual Sprint convertible
I dont have any fancy pictures of the conversion, But after tinkering for about 2-3weeks it's in the final stages. I finally figured out what i was going to do for the auto/manual mounting for the tranny. I drilled the 4 holes for the manual mount through 2 layers of the frame. Im not sure if this will hold, or whether or not it will buckle in. I was pondering the idea of using foam and filling the inside where the bolts go through.
I turned the engine over, but it seem's it will not start without the Turbo fuel pump. I was scared i had not done the timing right, but double check and re-set the belt. Still the same outcome, it'll rotate but wont fire.
And so i wait for the fuel pump.
Always make sure you have everything for the conversion, as it is a real pain in the arse if you leave components out.
CJDavE wrote:
" Only qwall is thinking about what's in my pants."
PostPosted: Mon Aug 17, 2009 1:03 pm
do you have spark? you need an igniter for the T3 ECU
Suzuki Gold Master Tech
PostPosted: Mon Aug 17, 2009 7:54 pm
yep thats all hooked up. It rotates, i think its the fuel pump that i need to put, since its still n/a one. though turning over seem's a bit loud.
PostPosted: Tue Aug 18, 2009 1:23 am
Drill larger holes in the wheel well and put nuts on those bolts. Or drop your transmission on the road. :shock:
accessholes.jpg [42.06 KIB]
Downloaded 887 times
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Tue Aug 18, 2009 12:57 pm
what size are you using?
Im using 3 of the same bolts the ones u put through the centre of the engine mount. with lock washers all around going through both sides
PostPosted: Wed Aug 19, 2009 8:27 am
I used the factory bolts. I just drilled the outer holes so I could get a nut and socket in there.
PostPosted: Wed Aug 19, 2009 10:47 pm
When you bring the turbo secondary harness into the car normally theres a clutch and brake 2 pin connectors that run to the clutch and brake.
trying to use the automatic n/a secondary harness it has 1 4pin connector going to the brakes. I have taken the 4 pin's out and hooked up 2x 2pin connectors to hook up to the clutch and brake. Do these wires even do anything anymore? have i missed something?
PostPosted: Fri Aug 21, 2009 6:18 am
According to my '93 Metro service manual, the white/yellow and green/white wires are for the brake lights and the orange/black and green/black wires are for the automatic shift lock solenoid.
PostPosted: Fri Aug 21, 2009 1:22 pm
:) Apparently i hooked them up right because i have reverse and brake lights. All lights work :)
PostPosted: Sat Aug 22, 2009 5:50 am
Good job! :clap:
