It is currently Sat Oct 21, 2017 11:10 am
PostPosted: Thu Jan 28, 2010 10:45 am
Hey, i have a 99 Suzuki Swift . with a 1.3l vin 2S2AB21H2X6601335
Needed to know if a motor from a 99 Geo Metro would work?
Was sure it would, since all its other parts are interchangeable. but the place where im getting the motor from just called me back and said he wasnt sure .
Anyone hae any experience in such?
PostPosted: Thu Jan 28, 2010 12:47 pm
should be identical, as long as its the 1.3 and not the 1.0
08 Civic Wife's car
PostPosted: Thu Jan 28, 2010 1:28 pm
Parts guy says that the block looks different.
so idk.
Currently waiting to see if he can send me a pic of it so we can compare..
PostPosted: Thu Jan 28, 2010 2:15 pm
they both should be multi-port fuel injection with coilpacks
if they both are, you're good to go. the mk5 1.3 blocks are the same
08 Civic Wife's car
PostPosted: Thu Jan 28, 2010 2:55 pm
Just got a call..
He said the blocks are different and its not going to fit.
tears..
PostPosted: Thu Jan 28, 2010 3:04 pm
98-01 Metro/Swift 4 cyl motors are the same. The Metro was available with a 3 cyl also.
PostPosted: Fri Jan 29, 2010 2:25 am
100% the same, but you better clarify that they are both 1.3 4cylinders. The swift will be 1.3 only option, but the metro can be 1.3 or 1.0. That maybe the confusion. The parts guy may be looking at a 3cyl and correctly telling you it won't swap directly. What happened to your 1.3? They are super tough little mills!
