It is currently Fri Oct 20, 2017 1:12 pm
 Post subject: geo to swift swap
PostPosted: Mon Feb 22, 2010 7:32 pm
I need a new motor for my 92 geo metro 1.0 3 cylinder. i wanted to put in a swift 1.3L but i just needed some help before i do that.
If i get the swift engine and want to put it in, do i need a new trans? or does this engine mount to the trans? and is there anything else i need to be replaced then as well or is it just swapping engines no problem. thanks.
 Post subject: Re: geo to swift swap
PostPosted: Mon Feb 22, 2010 8:24 pm
oh and i would also just need an ECU from a 1.3L geo right?
PostPosted: Mon Feb 22, 2010 8:57 pm
and where can i buy the swift engine from?
PostPosted: Mon Feb 22, 2010 9:02 pm
You will need the engine, motor mounts, clutch/flywheel, complete wiring harness and electronics including everything from the dash forward as well as the ecu and fuse blocks. Depending on if you are going to a sohc or dohc you may or may not need fuel pump and a few other things. I did this swap twice in the last few months and if you need any help feel free to pm me. I also have an extra sohc swift donor car if you want, it is much easier to do the swap if you have the entire car.
http://www.freewebs.com/rmp-motorsports/
