It is currently Sat Oct 21, 2017 6:04 pm
 Post subject: Motor swap
PostPosted: Wed Apr 21, 2010 2:48 pm
Hello,
I own a 97 Geo 1.0 i want to swap it with a 4 cylinder, anyone know if there are any direct bolt 4 cylinders that would fit with out too much mods ??
 Post subject: Re: Motor swap
PostPosted: Thu Apr 22, 2010 3:45 am
there are no 'drop in and go options" all will involve different mounts, trans linkage, exhaust, computer etc. Think about a cam and cam pulley to increase your 3cyl power, or if its tired freshen it up, you may pick up some power after new valves and rings are installed.
PostPosted: Mon Oct 11, 2010 9:43 pm
Geo32506 wrote:
Hello,
I know this is not what you're looking for - but - there are whole different swaps people do with Geo's - and that is to swap out the gas and Go to an Electric Motor, Which requires the use of an adapter plate, like was done on the one I am driving - which was converted some 14 years ago. See http://www.myelectricfly.com for more on it.
I will be exhibiting it at EV Fest, where there will be one of our exhibitors that loves to do the kind of things your looking to do - Aaron Cake!
Anyway - As I have seen a 1.2 L VW Lupo Diesel installed in a Honda Insight on the web - done by an aquointance of mine, http://99mpg.com/Projectcars/redlightracingworl/ - I am sure you could probably put the 4 Cylinder in that Geo, but you might need to add in a 4 Cylinder tranny too!
For updated info - see my Electricfly Blog, Some Technicals - www.evalbum.com/
PostPosted: Wed Dec 08, 2010 10:43 am
the swap hinges on one thing... will a 5 speed from a 1l bolt to a 4cyl. basically do all G blocks use the same bellhousing?
PostPosted: Thu Dec 09, 2010 5:32 pm
Yep.
PostPosted: Thu Dec 09, 2010 6:19 pm
not a problem as long as you use the compatible engine mounts and axles. little things like the clutch cable being a shade longer on the 3 banger won't matter.
