It is currently Tue Jan 16, 2018 2:47 am
PostPosted: Sun May 09, 2010 9:22 pm
ok I am working and a motor and a transmissiom swap.I going to use a swift motor and samurai trans in a mg midget.But have learned that a samurai transmission and transfer case can be spilt but the transmission has no speedometer gear.
So now how to get the speedometer?any ideas guys
PostPosted: Mon May 10, 2010 11:33 am
I don't know much about Samurai transmissions, but I do know that there was a 2WD version. I'm sure they had speedometers.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Mon May 10, 2010 1:55 pm
2wd samurai's had a dummy transfercase, the transmission was the same.
You could look into drilling the spindle for a cable, like an air cooled volkswagen would run?
PostPosted: Sat May 15, 2010 10:33 pm
Sort of a small world. I'm putting a G10 engine and sammy transmission in a Miata MX5.
I spent the last 6 months collecting all the parts. Tonight I brought the Miata home.
Anyway with your speedometer issue... I have sort of a hillbilly fix that will work.
Get a digital bicycle speedometer, put the magnet on the driveshaft and calibrate the speedometer accordingly. All bicycle spedo's allow the user to input special calibration factors.
As I recall the Midget transmission tunnel is boxed in so you may have to put the magnet on the front rim.
Anyway it works! I used this setup on my dune buggy (magnet on front brake drum).
Good luck with your MgUki...
PostPosted: Sun May 16, 2010 8:06 am
talk to geopat, he's got a sammy
also check out
zookpower.ca its more of a suzuki samurai based forum
08 Civic Wife's car
PostPosted: Tue Jun 01, 2010 2:13 am
I'm putting a '89 G10 in a midget.
I got a '91 2wd tracker 5-speed. It had a speedo cable in the trans.
My problem is the bellhousing doesn't match up with the G10 motor.
The lower studs don't match (upper bolts do).
Jack
PostPosted: Mon Apr 04, 2011 1:01 am
I just bought a cheap GPS and stuck it on the dash. Shows realtime speed.
PostPosted: Mon Apr 04, 2011 2:05 pm
Jack
Yeah, the 1.0/1.3 bellhousing pattern is different from the 1.6 bellhousing that your 91 2wd tracker trans would bolt up to.
Your options are:
1) find a RARE 89 1.3 track / kick 2wd trans, only year that I'm aware of that that trans would bolt to a 1.3
2) build an adapter plate
3) weld up the lower holes/ add metal and redrill
