It is currently Wed Oct 18, 2017 10:27 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
 Post subject: Suzuki Justy GTi AWD
PostPosted: Mon May 10, 2010 4:48 pm
My gf got in a minor accident a week ago, she's fine but her GTi got hurt pretty badly:
File comment: Ouch. Looks like a big fenderbender, but there is extensive structural damage underneath
Damage is structural and too expensive to repair properly. The rest of the body isn't in great shape either, so it's time to say goodbye, but not before we take everything useful out of it. That would be the engine, wheels, hubs, brakes, struts, sway bars, steering rack, wheel and column, dash, swithes, headlights, wiring, bumpers etc. All that stuff is going to end up in and on this car:
File comment: 99 Subaru Justy
A 99 Subaru Justy, with a 1.3 8v sohc (the only engine availabe in the "Subaru Swifts", the Suzuki's had the 16v sohc) and AWD :D I took the time to compare the car to mine to check for differences and possible problems and thought the info could be useful to others so I figured I should post it here. This is what I found out up to now, apart from cosmetic differences:
- floor pan is the same, except for the rear part, no spare wheel compartment. Spare goes in the trunk
- driveshaft goes where Swifts have the exhaust
- fuel tank is different to make room for the driveshaft
- exhaust hangs lower and more to the right and is straight from front to back until just before the rear muffler, which is in the rear left, with the tailpipe ending in the usual place
- cat is mounted solid to the rear engine/gearbox mount
- cable shifter, no room for shift rods under the car
- speedo cable can be unhooked near the firewall
- wiring, fusebox, bulbs, connectors and most of the switches are different
It's too much work to splice the engine and body wiring together and since the interior is coming out anyway, we might as well swap the entire wiring loom. In fact, the only things we will be using are the shell and drivetrain, the rest will become Swift GTi, with a turbo added somewhere in the (near?) future. The front will be MK2/3. That's it for now, updates with pictures will follow =)
'95 Swift 1.0:
- 0,5mm oversized pistons
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- TBI bridge removed
- srd underdrive pulley
- GTi catback
- deleted cat, now 2" ss pipe
- 14x6J ET45 BSA Racing
- Nankang AS-1 165/55-14
- GTi sway bar
- Turbinetech underbody brace
0-100kph: unknown seconds
 Post subject: Re: Suzuki Justy GTi AWD
PostPosted: Mon May 10, 2010 8:28 pm
new car looks pretty clean. could you take a picture of were the cables come though the fire wall when you get the motor out.
also do suzuki sidekicks/vitaras have folding mirrors in the netherlands?
1994 suzuki sidekick 4 door
PostPosted: Tue May 11, 2010 2:36 pm
It's a pretty clean car, except for the front. Doesn't matter, because it will get a MK3 front anyway. Saved about 900 euro's that way. If it was in good shape, it would have cost twice as much 8)
I took some pictures of the cables today, but I forgot to take my camera with me, so I'll post them when I get home tonight. The cables go through right beneath the heater hoses.
I haven't seen a Vitara in the wild yet, but as far as I can tell from pics, they have folding mirrors here.
Edit:
Here's the picture, you can see the heater hose above it. I'll remove some parts tomorrow to get a better shot:
Here you can see the coolant pipe go over the gearbox, to make room for the shifting mechanism, you can see the cables right behind the clutch cable bracket. Release arm is bent upwards because of the coolant pipe:
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Sat Jul 03, 2010 7:46 am
Talking about my new Subaki i see. hmm.
I hope it will be a lot of fun to drive when it's finished.
GTi AWD Turbo
Muhahaha
X Roxy (Peenutzz' GF)
Cultus GTi AWD AF34S
'97 Justy tranny + AWD setup
'93 GT engine, wire looms, interior, brakes.
3 tech cams
K&N cold air intake
SuzukiRD racing header
Custom 50 mm steel exhaust system
QSP racing steering wheel
Future Plans
Garrett GT1549
Intercooler
HKS BOV
MS2 ECU
PostPosted: Sat Jul 03, 2010 7:21 pm
hey. keep us posted. looks like a good project.
i've been curious about the justy's.
92 swift ga coverted to gt. always a work in progress
PostPosted: Mon Jul 05, 2010 11:39 am
How hard is it to pick up a justy over there? Ive been looking at bringing one over, If I could find one with front end damadge like that, it would be preferable...
90 Swift parts car
93 sohc swift Ga might part out soon
89 Swift Gti pulled from Arizona Big project
PostPosted: Mon Jul 05, 2010 5:27 pm
Justy's aren't that hard to find here, prices vary from 1500 to 2500 euro's for a decent one and sometimes there are cheaper ones, usually with (minor) damage. There's a '97 for sale now for only 750 euro's, looks clean on the pictures: http://link.marktplaats.nl/359004528
Don't know why it's so cheap and now we wish we had bought this one :shock:
This week we plan to swap the engine, we unhooked the last few things today, GTi engine is already out, only need to remove the gearbox.
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Mon Jul 05, 2010 6:05 pm
Thats a perfect example of what Im looking for any idea what shipping would look like?
90 Swift parts car
PostPosted: Mon Jul 05, 2010 8:53 pm
I honestly don't have a clue about such big shipments. Now I think about it, I rarely send anything by mail, I only order stuff =)
I believe there are some topics running about importing cars to the US, maybe they can help you there.
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Wed Aug 18, 2010 1:51 am
I just found out about those cars; I want to do a swap with the AWD and a G10 motor, into an early mini pick up! is there a positive connection between front and rear, or can one turn without the other? How much does the all wheel drive improve traction? Would it help with off road driving much, or is it not worth the effort? I am familiar with doing complicated swaps, just don't want to waste my time if most of the drive is still going to be up front.
Thanks, Steve
PostPosted: Wed Aug 18, 2010 1:54 pm
Steve, some of the pics have gone dead but this thread may answer a lot of your questions:
http://www.redlinegti.net/forum/viewtop ... 1be27a13f1
PostPosted: Wed Aug 18, 2010 3:06 pm
thanks alrwerks, good info, if not pics. looked at the u-tube vid link; lots of 4x4 swifts there at the digs! Just need to find a donor cultis or justy now; they didn't get to the States.
Cheers
PostPosted: Wed Sep 15, 2010 3:52 pm
New update :D
We had nice weather the past two days so we got some major work done. Roxy doesn't like power steering and wanted to use the steering rack from her GTi. We test fitted everything and figured it should work. Here goes:
The GTi rack fits, it has the same mounting points as the Justy's. There are two differences: Rack is mounted higher so the linkage to the steering column is too long, can't use the one from the Justy because that one is too short and the splines are sized differently, so the GTi column has to be used also. Other problem is the hole, it's too high as you can see in the pic. This is what Roxy did:
Put on her welding equipment:
They say she drinks high octane fuel on the rocks with breakfast
Remove the hole with a Dremel:
Transplant the hole to a new piece of 0,8mm steel sheet and tack that into place:
And after a few hours of grinding and welding, this is the result:
Outside:
While she was busy with the hole, I took care of some other things. The rod to the steering column was too long:
I solved that by grinding off a piece and making a new slot for the bolt:
The steering column end needed some grinding too. The splines needed to be removed partially so that the shortened rod would go in further:
Now it looks like this. Fits nicely and turns smoothly :D :
I also put the struts and knuckles back on the car, together with GTi brakes. We had a machine shop take a few millimeters off the discs to make it work. Same guy also did the flywheel. Blasted it and took some weight (almost 2kgs) off. Now it's about the same weight as a stock GTi's:
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Wed Sep 15, 2010 9:48 pm
WOW man Thanks for posting this!!! Ur pics have been a BIG help to me! I'll Hafta post some up too... I've looked and looked tryna find a pic of the AWD,LHD firewall (as opposed to the AWD,RHD versions...) THANKS BRO!
All Wheel Drive-187 FWHP @ 18 psi...... SHE LIVES!!!!
METRO SS Certified honda H8R
AHM NOT AN AHSOE!!! DO I LOOK LIKE AN AHSOE!?!?!?
PostPosted: Thu Oct 07, 2010 2:32 pm
Got some pictures of the Twincam with Justy gearbox:
We actually got it in the car today, but I didn't have a proper camera with me. It was a very tight fit through the top :P Now all we have to do is plug it in, fill up the gearbox and cooling system and we should be ready to fire it up :D
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Tue Oct 12, 2010 6:01 pm
We fired it up today :D :D It took a few days longer than expected, making an exhaust system turned out to be not as easy as it looks. While Roxy took care of that, I took care of the dash and the wiring. I had to replace the headlight plugs, and fix the wiring to them, because it was a bit of a mess. Lights weren't working properly before, so after I fixed the plugs, I opened up the steering column switches to find a loose wire. When that was fixed, there was light again :D
I put the dash back in, figured out the wiring and everything worked, except for the front fog lights and the heater motor. Turned out I forgot the fog light relay and didn't plug the motor in, so that's fine now 8) There's only one strange thing: The rear fog light switch indicator light is lit when the lights are off and when I press the button, the lights go on but the indicator light goes off :? I'll try another switch tomorrow.
Roxy finished the exhaust system today and when we fired it up it turned out to be VERY LOUD. It's made of an SRD header, a GTi cat, 2" steel pipe to the rear and a small fart can at the end. An extra silencer has been ordered about an hour ago :P I'll take my videocamera with me tomorrow and post some videos.
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Tue Oct 12, 2010 7:21 pm
I been trying to find the location of the rear fog relay plug for ages. I just need to plug the relay in and I'll be ago go...
Could you describe in quite a bit of detail exactly where I need to look?
Thanks
Jon
PostPosted: Wed Oct 13, 2010 3:20 pm
I was talking about the front fog relay before. I haven't run into a relay for the rear fog lights and the wiring diagram doesn't show it either.
We drove it for the first time today, but took it easy because of the noise. We went straight to a garage to check it for MOT. There turned out to be a few minor issues but apart from those it passed. Even emissions were good :D Some pics I took today, before we took it to the garage:
I'll post some videos later, they're on my laptop.
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Fri Oct 15, 2010 2:12 pm
Some videos:
http://www.youtube.com/watch?v=LgcjjaMhqi0
http://www.youtube.com/watch?v=6Ul_8Xvcf-I
http://www.youtube.com/watch?v=o3oTBdSfC1M
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Mon Oct 18, 2010 8:28 am
Now I've driven it a few times, I must say I like it. Ofcourse, it doesn't react like the FWD I'm used to, and that way I accidentily discovered that it's possible to drift :twisted: Best of all is that even in the rain, there is instant grip when accellerating from a standstill. Just drop the clutch and floor it, it will go without wheelspin. Sweet. Now I want AWD for my 1.0 =)
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Mon Oct 18, 2010 8:17 pm
me too. =)
PostPosted: Wed Oct 27, 2010 10:38 am
Wow, great project! And your GF rocks, for working on her own car :thumbsup:
Now that I see these pics and hear your comment about being able to dump the clutch without wheelspin it makes me regret I used a GTi shell instead of a Justy :|
Do you happen to post on any Dutch boards?
PostPosted: Thu Oct 28, 2010 10:10 am
I found Teamswift when I was looking into 1.0 turbos. Dutch people don't do that very often :P I don't post on Dutch forums, I take a look sometimes, but that's all. Maybe I will start posting when I start my turbo project somewhere next year :)
'95 Swift 1.0:
- ss exhaust valves
- 222/365 3tech cam
- +10 gear
- K&N air filter
- GTi catback
- GTi sway bar
PostPosted: Fri Oct 29, 2010 3:20 am
I'll send you a PM.
PostPosted: Tue Nov 02, 2010 10:33 am
did you use the GT brakes/calipers both on the front? do the calipers bolt on directly to the hubs? I've got a set of GT brakes I've been wanting to put on my car, but I didn't want to have to change the axles(GT hubs have larger splines).
