It is currently Tue Feb 20, 2018 1:32 am
 Post subject: 92-96 swap?
PostPosted: Tue Jun 15, 2010 6:32 pm
Can I swap a 92 XFI motor into a 96 Base Geo? the XFI is complete and on the cheap.
Thanks in advance.
Mike
 Post subject: Re: 92-96 swap?
PostPosted: Mon Jul 19, 2010 12:55 am
Yes but lots of work. You will need to swap over a lot of stuff, more if the 96 is a 4 cylinder. Look around using the search tool, you should find all the info needed. This would be better posted in the Mk2 Mk3 non turbo category. This section is mainly for conversions to the GTi or turbo engine.
PostPosted: Mon Jul 19, 2010 9:08 am
You can, but for the 96 computer to run the engine, you need to swap the oil pump, oil pan, crank sensor, crank and cam gears, and belt to the XFi engine. Use the intake manifold from the 96 also.
The head and block are the same.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Mon Jul 19, 2010 5:14 pm
read here for that info. it isn't expressly for the xfi but it covers most of the big stuff.
viewtopic.php?f=30&t=34924
