It is currently Thu Jan 18, 2018 1:19 pm
PostPosted: Sat Jul 17, 2010 5:19 pm
My friend and I are cruising around a relatively large junk yard (for the back wood location). We go here because parts are cheap, and can find just about anything. So we find an 05' Dodge SRT-4, looked like it had something relatively large shoved up it's back end. We figure one of my Metro verts and it might just be a compatible match for each other, but were just not sure.... How many people have actually managed to put an SRT-4 engine in a geo metro vert? if any?
PostPosted: Sat Jul 17, 2010 8:26 pm
True, but there is a lot more hot rod in that engine than in your 1.3 liter. Nearly double the displacement, to start with... plus the SRT-4 motor is one of the easiest to upgrade because of the massive Mopar support.
Still seems like a pipe dream to me, quite frankly...
PostPosted: Sat Jul 17, 2010 8:49 pm
srt-4 in the wifes dodge rampage :twisted:
08 Civic Wife's car
PostPosted: Sun Aug 01, 2010 12:56 pm
You should join the Shelby/Dodge Auto Club
http://www.sdac.org/
You don't need a Shelby
and join the following forum
http://www.turbo-mopar.com
There are members putting the SRT4 motor into the k-car station wagons and even mini-vans. My SRT4 weighs about the same as the 87 Voyager I used to have. We have already crunched the numbers and if we put the motor from my 12 second SRT4 into my 84 Horizon (about 1000 less lbs) it should run high 10s in the quarter and my current Horizons 23 mpg should go higher thsn the 33 I now normally get in the SRT4!
36 time NHRA/IHRA Champion
05 SRT4 / 12.79 @ 111 mph / 40.1 mpg!
01 Voyager V6 / no mods yet / 24 mpg
84 Horizon / 1760 lbs / was 17.9, now 23.0 mpg
96 Geo Metro / 1590 lbs / was 46.2, now 60 mpg!
95 Neon / unk mpg so far
PostPosted: Sun Sep 12, 2010 8:25 am
Ill just say with it that it would be a bit difficult to use the turbo sense it is built into the heared. The ehaust housing is the hot side of the turbo
