It is currently Fri Oct 20, 2017 9:29 pm
PostPosted: Mon Oct 25, 2010 2:26 am
Does anybody make a distributor that will work in my 3-cyl engine totally independent from the computer?? I am looking to find a way to completely ditch the computer..I would like to run a low pressure 'dumb' carburettor, non-computerized distributor and have a simple car..I know it sounds like heresy, but I'm looking to get back to basics. Thanks!
PostPosted: Mon Oct 25, 2010 9:24 pm
why not toss a points distributor and a mechanical fuel pump while you're at it :roll:
get a mk1 distributor, I think it's exactly what you're looking for.
Suzuki Gold Master Tech
PostPosted: Tue Oct 26, 2010 5:12 pm
the mk2 distributors are vacuum advance.
PostPosted: Tue Oct 26, 2010 7:53 pm
those should have weights and springs under the breaker plate, too, and i think that the dizzy module on the mk2 directly fires the coil.
PostPosted: Wed Nov 03, 2010 12:28 am
Hello, I'm planning to be replace my distributor with a distributorless ignition, using Coil-On-Plug.
Of course it will have a microprocessor to control it.
But it would work independent of the existing ECU, so it'd work with a carb, etc.
Are others interested in such a setup?
Jack Murray
PostPosted: Wed Nov 03, 2010 9:40 am
Definitely interested. Would prefer to fire COP with a MSII, is that the controller you plan on using?
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Wed Nov 03, 2010 7:41 pm
I won't be using MegaSquirt, but one of my Microprocessors boards.
I have maybe hundreds (at least dozens) of MSP430 micro boards I designed for wireless control of R/C cars.
I closed the business and now just have them surplus.
So I will use one of these as the brains. I will need to create an daughter board to handle firing the coils,
and read the vaccum sensors.
I think they may even sell such a board for the MS, but its not a complicated thing, just need to handle the voltage spikes.
PostPosted: Wed Nov 10, 2010 3:04 pm
what do you plan to use as a trigger if you remove the distributor?
