It is currently Wed Oct 18, 2017 1:39 am
PostPosted: Tue Dec 14, 2010 10:30 am
Put a geo metro 1991 1.0 engine in a 1994 geo metro (was 1.3 engine). In order to plug in all wiring harnesses to the throttle body, a later throttle body is required. What years will bolt onto the intake of a 1991 1.0? 1992-1995 (for a 1.0) ? :D
PostPosted: Tue Dec 28, 2010 5:44 pm
the g10 takes a different sensor array than a g13.
i have a serious question as to whether the g10 would even run at all with the wiring and ecu for a 4 banger.
as always, the best way to go is to take the ecu and wiring harness along with the engine from the donor car and install it as a system. also, you'll need to replace the instrument cluster or recalibrate the tach for 3 cylinders (if tach equipped.)
