It is currently Tue Oct 17, 2017 2:23 pm
 Post subject: g10 to g13b SOHC swap
PostPosted: Wed Feb 02, 2011 6:54 pm
i just got a reaaaally :shock: amazing deal on a g13b engine, twincam axles, custom crossmember, wriring and ecu
i was wondering do i really need the shift linkage from a 4 cilinder even if i have a custom crossmember??
and also what ECU will be plug and play?
suzuki forsa 1985 (SA310) with g13bb swap>>SOLD!
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Thu Feb 03, 2011 2:23 pm
here some pic of what i bought
axles
http://img52.imageshack.us/i/imgp0740z.jpg/
brake
http://img528.imageshack.us/i/imgp0743a.jpg/
engine
http://img196.imageshack.us/i/imgp0744qf.jpg/
g13b 1298cm^3
http://img96.imageshack.us/i/imgp0745m.jpg/
engine
http://img193.imageshack.us/i/imgp0749e.jpg/
engine
http://img715.imageshack.us/i/imgp0750.jpg/
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Thu Feb 03, 2011 5:07 pm
Wiring will need to be swapped out, different sensor set, and the shift linkage must be changed since the 4cyl has the linkage on the opposite side of the shifter as the 3cyl.
PostPosted: Thu Feb 03, 2011 7:44 pm
i got a wiring harness and ecu of a 1.3 so i dont think theres any issues with that, the thing that worries me is the shift linkage. but i was cheking things out and i thing i can modify my current one....you say the linkage is on the opposite side???i dont get that
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Tue Feb 15, 2011 9:35 pm
hey ,papo this is Noly did you get to talk to the guy for the swap.
PostPosted: Wed Feb 16, 2011 6:07 am
yes i talked to him but he said that couldn't do it becasue he has too much work but he gave me the phonenumber of another guy in camuy who can do it in summer, thanks anyways :!:
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Wed Aug 31, 2011 12:29 pm
started the engine swap! got some problems with the long axle...the part that goes bolted to the engine wont fit for like 1/4 inch and we wont force it in because we dont want to damage the transmision....any help would be apresiated
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Wed Aug 31, 2011 4:58 pm
looks to me like that is an 1.6L engine from a suzuki esteem. reasoning is the extra linkage on the throttle body for cruise and the boxy design intake plenum.
PostPosted: Wed Aug 31, 2011 5:21 pm
is a 1.3 SOHC 16V engine from a japan spec suzuki swift gesta. that is how you know it is from japan, the intake manofold and TB are from a baleno(esteem) 1.6 and of course it has to say made in japan.
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
PostPosted: Mon Sep 05, 2011 9:05 am
here is an update on how it is going
have had some problems with the custom crossmember, and custom shift linkage, also de exhaust manifold rubs with the radiator fan.
suzuki samurai 1989
webber 32/36
header with 2" pipe
2" lift in front
30" tires
