It is currently Sun Oct 22, 2017 11:38 am
PostPosted: Tue Dec 04, 2012 10:26 am
Hi, does anyone know if the latest 3 cylinder 1000cc Suzuki 'Splash' engine will fit onto a Suzuki Jimny Mk2 rear wheel drive gearbox? Suzuki stopped production of the 3 cylinder 1000cc 'Swift' engine about 2006. Any information would be much appreciated.
Liege Motor Company
(there are now nine Liege fitted with the 1000cc Swift 3 cylinder engine attached to the Jimny Mk1 gearbox)
PostPosted: Tue Dec 04, 2012 12:53 pm
Won't get much luck on this forum as it's mostly North American and they don't get even get the new generations of Swift, considered too small for the market, let alone the even smaller Splash.
I suspect the Splash is using a K10 which has been used in previous model alto's, in which case the gearboxes share identical ratio's to the g10/g13 fwd gearbox which leads me to think the gears are the same but probably the countershaft and diff will be smaller, Suzuki did a similar thing with the g13 4wd and g16 cable shift box.
I think you'd be out of luck trying to mate a k10 to a g10 bell housing, anything is possible but the K and G formats are definitely different.
PostPosted: Tue Dec 04, 2012 5:56 pm
suzuki may have ceased production of the g10 engine but they are still replacing them with new crate motors every 30 to 40 thousand miles for air pollution certification in japan.
the old, low mileage engines get cleaned, loaded into containers, and exported. you might have luck locating one on the used market. as long as it doesn't glow in the dark you'd be good to go. :wink:
PostPosted: Sun Dec 30, 2012 7:05 am
I wondered where that light was coming from. :shock: :lol:
PostPosted: Sun Dec 30, 2012 5:15 pm
I'm not sure which model you refer to as the MK2, if you mean the M13 engined models then that gearbox will not mate up to an engine with a G13 bolt pattern. Auszookers.com or bigjimny.com are probably your best bet for information.
