It is currently Wed Oct 18, 2017 9:06 pm
 Post subject: saw a kit for a sami
PostPosted: Tue Apr 30, 2013 8:36 pm
would a sami kit work on a swift to swap in a 1.6 td vw engine?
 Post subject: Re: saw a kit for a sami
PostPosted: Sat Jun 01, 2013 8:37 am
the only thing that will work would be the adapter and flywheel. You will need to fab up mounts and figure out which acc you will need and from what model. Im not sure how well the flywheel will work. I put a swift motor in my sammi in highschool and used the swift flywheel cause it was lighter and there was something different about it that wouldnt allow the clutch to fully engage so it would slip at high rpms and not cause it was a bad clutch it was brand new. I even broke the center out of that clutch and put another in and did the same thing. Just my 2c on the subject.
