It is currently Tue Oct 17, 2017 4:48 pm
PostPosted: Fri May 16, 2014 1:34 am
So I have a '99 Swift and would love to convert it to propane, but it seems there aren't many options for fuel injected engines, especially the G13BB. However, I've heard it's super easy to convert the Samurai carbureted engines to propane. I've also heard that a lot of offroaders love swapping the fuel injected Swift engines into their rigs.
So what I'm wondering is: is the reverse true? Could I swap a carbed Samurai 1.3 into my Swift? Better yet, could I just swap the Samurai intake and carb onto my existing G13BB head?
PostPosted: Fri May 16, 2014 2:36 pm
I'm pretty sure that is possible to swap Swift (GTI) engine to Samurai.
So it should be possible.
plotowanie radom | cadprint.pl
PostPosted: Fri May 16, 2014 2:48 pm
I would imagine the transmission bolts and engine mounts are the same. The bigger concern is probably hood clearance, though.
PostPosted: Fri May 16, 2014 4:11 pm
I did this in a 89 swift but changed the cam and intake to the tbi one on a swift. Almost every thing bolt up. Where I had my trouble was where the stub axle for the 1.3 swift bolts to the block in the rear. all the holes were not there only 1 of the boltholes was there so I made a bracket to hold it in place.
Cars and Harleys
PostPosted: Fri May 16, 2014 7:46 pm
The samurai intake will only fit the 8valve cylinder heads. probably be the easiest to find a 8valve 1.3 motor out of a mk2/3/4 car.
1994 suzuki sidekick 4 door
PostPosted: Sat May 17, 2014 1:58 am
Sounds like it'd be ideal to use the original block with a Samurai head. But making a bracket isn't the end of the world. So you used a Sammy block and head, but Swift cam, intake, and tbi?
The car in question actually has a bad head gasket which I was about to replace. If I can track down an 8-valve 1.3 head, will it bolt right up?
PostPosted: Sat May 17, 2014 5:27 am
Complete sammy engine just swapped cam,intake and dizzy,oil pan,exhaust manifold. I am sure there was a few other thing i am forgetting but you get the jest of it.
Cars and Harleys
PostPosted: Sat May 17, 2014 5:38 am
So you installed a Swift intake on a sammy head?
