It is currently Fri Oct 20, 2017 1:43 pm
PostPosted: Sun Aug 23, 2015 12:33 am
I wanted a crankshaft under drive pulley that had the A/C pulley also.
No one makes it so I made one.
I started out with a 4.0" round bar stock in 6061 grade.
A days worth of machining and I have a double under drive pulley.
3926 says a lot. From left to right it shows the 4.0" bar stock, the 4.0" under drive pulley I made, a 1.0L stock double pulley with
AC, a stock 98 1.3L with dampener, and a crankshaft sprocket that was used as a tool for holding the 4.0 under drive pulley in the
lathe to do the machine work.
3943 shows the undercut on the back side of the pulley so it doesn't rub the timing cover. It also shows the weight of the pulleys.
stock 98 1.3L with AC and dampener 4.06 pounds
stock 98 1.0L with AC 2.71 pounds
my newly made under drive pulley with AC 1.14 pounds
3930 I would recommend using the longer pulley bolts.
3950 Installed on the 98 SOHC 16 valve motor just for the picture.
The only thing left is to get it Anodized. I will do it in red to match the rest of the DOHC aluminum parts.
If it works out I may start making these to sell.
Fainya
PostPosted: Sun Aug 23, 2015 9:09 am
Looks good keep us informed on how it is going! And no I still have not got that transmission in yet! :lol:
Cars and Harleys
PostPosted: Sun Aug 23, 2015 3:47 pm
Very nice fainya :D
If it works out well and you do sell some put me on the list first :D
PostPosted: Sun Aug 23, 2015 7:28 pm
The cost to get them hard anodized may be high.
If you have an anodizing shop that is reasonable
please let me know.
I can get the equipment to do hard black anodizing
for about $1000, and it will also do the softer primary colors.
For longevity I would want the hard black.
If I start making lots of aluminum parts the cost of bringing in an anodizing
system may justify itself.
Fainya
PostPosted: Tue Aug 25, 2015 9:04 pm
Pulley was installed on the DOHC engine tonight and I will road test it in the morning.
Still not anodized yet but I want to make sure I got everything else right.
Fainya
PostPosted: Tue Sep 01, 2015 9:08 am
Pulley and new belts have been working now for over a week with out any problems.
I will be making another 5 pulleys and then send them over for hard anodizing (makes the parts as hard as steel)
TH cost of anodizing will set the final price for the pulleys.
Fainya
PostPosted: Tue May 17, 2016 2:27 pm
Hi mate,did you ever get these made?if so are you selling any?thanks Dan
PostPosted: Sat May 21, 2016 4:19 pm
He has them for sale. Send him a PM.
