It is currently Fri Oct 20, 2017 5:44 pm
PostPosted: Mon Feb 22, 2016 7:24 pm
I have a manual trans 95 Geo Metro Lsi 1.0 3-cyl engine. Wondering if I could swap the engine into an automatic trans Suzuki Swift 2001 1.3 4-cyl. If yes, what parts would need to move from the donor car?
PostPosted: Mon Feb 22, 2016 8:52 pm
If you have the donor car, swap everything, engine, trans, cv shafts, moubts, wire harbess, computer, hoses, etc. Radiator may work on either. 95 is obd1, 01 is obd2. That is why youd have to swap the wiring harness and computer around. It will be a long process, probably be easier to buy a manual trans G10 car with a bad drivetrain and swap in your good drivetrain. If you like working on cars and like a project, doing the swap you wabt to do would be fun. Probably wouldnt cost much if you had the complete donor car to pilfer. It wont be cheap if you have to go to junkyards to buy all the little stuff youll need.
Users browsing this forum: No registered users and 7 guests
