It is currently Tue Feb 20, 2018 6:57 am
 Post subject: Toyota dizzy for g13b
PostPosted: Mon Oct 16, 2006 3:50 am
OK here's one for everybody who wants to run an aftermarket ECU but has the same old problem with the non-standard suzuki dizzy.
I spent a couple of hours sifting thru two pellets of distributors until I found this one, it's off a toyota cynos, 4afe? it's also the same as 4age dizzies apparently. The engagement tooth fits perfectly into the end of the cam, the only difference is the shaft is longer than the suzuki one, so you can use the whole distributor without modification with a suitable adapter.
This dizzy has 3 pickups, 24 teeth on the top wheel and 2 on each of the lower wheels so I can run sequential injection with my microtech.
Since I'm running quad coils I don't need the rotor so we machined the top off the dizzy cap.
PostPosted: Tue Oct 25, 2016 5:29 pm
work's good?
PostPosted: Wed Oct 26, 2016 12:54 am
:shock: ten year old post...
Yep works really well, enables you to get both cam and crank timing off the same unit.
PostPosted: Wed Oct 26, 2016 10:39 am
your image hosting is very good too. :lol:
I also am surprised nobody replies this thread... Anyway that dizzy looks simple and easier than install new CKPS sensor and modified CKPS.... Great job but I wonder what kind of aftermarket ECU do you use at that time?
sorry bout my bad english
PostPosted: Wed Oct 26, 2016 6:52 pm
i instal a injection and need solucion for crank angle sensor.
yep 10 years :razz:
PostPosted: Thu Oct 27, 2016 12:59 am
haha, dirty old photobucket, not sure why I used a image host instead of uploading it, oh well its survived numerous Team swift server upgrades over the years :lol:
You can see the old microtech on the firewall with x4 ignitor, have just finished rewiring the car as I needed to move the ECU.
PostPosted: Thu Oct 27, 2016 2:26 am
Damn very clean interior... I don't even see any pebble rocks in there. :lol:
I can see that aftermarket ECU... thanks.
