It is currently Thu Oct 19, 2017 6:46 am
 Post subject: Dome Clock Wiring Help
PostPosted: Fri Dec 20, 2013 8:16 pm
I'm installing my Swift Overhead Dome/Clock into my '94 Metro, and need someone to point me to where to tap into the ACC and Dimmer circuits, preferably at the fuse box. I have the constant 12v and grounds hooked up at the clock. Two wires run down the passenger side A-pillar and under the dash to the fuse box area. No existing harness in my car, so that isn't an option.
'94 Metro LSi 'Green Machine'
'94 RHD (Totaled)
Vail, AZ
PostPosted: Fri Dec 20, 2013 10:32 pm
i ran a peice of cat5e and doubled up the pairs, you can even run some 18/4, i fished it up using a fishtape, and i tapped into the existing clock wiring on my gt which was under the radio, but if its a metro not sure if they have the clock plug, you can use the radio wiring for all the wiring if you want.
08 Civic Wife's car
PostPosted: Mon Dec 23, 2013 8:09 pm
No plug. Hopefully someone has tapped in and can clear things up.
PostPosted: Sat Jul 09, 2016 6:19 pm
Resurrecting this to see if anyone has added a dome clock assembly into a car that doesn't have the factory harness/plug. Just curious what you tapped into. Maybe someone can post up the wiring schematic. That would be a great help. Thanks in advance.
'94 RHD (Totaled)
Vail, AZ
PostPosted: Sun Jul 10, 2016 7:16 am
I don't have diagram but I tied in to radio wiring with mine. It had all the things I needed. Constant power and wire for light control and ground.
Cars and Harleys
PostPosted: Sun Jul 10, 2016 9:34 pm
Yes, that's correct. I tapped into the area near the radio as well on our automatic GTi.
Or else there's a plug on the right side near the A-pillar.
There's a thread "Phils toy" which might explain it better.
The dimming circuit should also be tapped in there.
If I recall, you can use the dash light circuit.
There's a downloadable manual with the GT wiring here on Teamswift available for free.
PostPosted: Mon Nov 28, 2016 11:52 pm
Your talents surpass your loveliness.
slot online
