It is currently Thu Jan 18, 2018 10:32 pm
 Post subject: Turn signal switch
PostPosted: Thu Oct 23, 2014 3:54 pm
Hi everyone,
I know I'm new on this forum, however I'm not new to forums in general. I just picked up an 01 swift for my dad. The turn signals don't work but the hazards do. The guy I got it from has a 99 metro. I was going to try his turn signal switch. However they are different part numbers. Does anyone know if the metro switch will work in the swift? If slight modification is needed I can do that.. His 99 is a 3 cyl 5 so. My swift is a 4 cyl auto.
Thanks!
 Post subject: Re: Turn signal switch
PostPosted: Thu Oct 23, 2014 4:04 pm
the combo switch should be the same.
08 Civic Wife's car
PostPosted: Thu Oct 23, 2014 5:02 pm
It should be but it's not. I'm wondering if it will work tho... I don't want the guy to go through the effort of taking it off his if it won't work
