It is currently Thu Oct 19, 2017 8:47 pm
 Post subject: iac valve swap?
PostPosted: Wed Nov 05, 2014 10:36 am
I have a 91 geo metro 3 cylinder and a 92 suzuki swift gt with the DOHC. My swift has a check engine light for the iac sensor and it makes a ticking sound like a pcv. The iac off my geo is almost the exact same as the one on my swift. same size, plug for the wires fit. everything is the same.
are there any differences between the two? Can I take the one off the geo and put it on the suzuki?
part numbers are:
geo- 18117-60B10
suzuki- 18117+64B00
 Post subject: Re: iac valve swap?
PostPosted: Wed Nov 05, 2014 5:26 pm
64b00 is just a supercession part number. they are both the same and you should be able to just swap the solenoid valves and roll on. :wink:
