It is currently Wed Jan 17, 2018 6:32 am
 Post subject: ECM Harness Issues
PostPosted: Wed Dec 24, 2014 11:31 am
I am building/modifying a stock G10 harness. I have found the Metro harness I got from Pick a Part has small insolation breaks just at the connector exit. Has anyone found a source to the ECM connector receptacles?
Also if anyone has extracted these receptacles I could use some pointers on a tool and the easiest way to pull them out. The factory manual does not cover the ECM connectors. I have modified many Honda harness with no problem. The Suzuki is completely different having a strain relief built in as well as receptacle retainer. Or I have lost my touch.
The G10 is going into a 1971 Honda N600.
1971 Honda N600 Transplant
w/ Suzuki G10 engine
and 5 speed trans
